Fuel pump bracket
Old Apr 3, 2005 | 01:19 AM
kevsrs's Avatar
kevsrs
Default Fuel pump bracket
I'm not havin much luck in the rust department at the mo
I didn't realise mine was bad till i went to get the pump replaced and when the bracket came off so did the fixing and pile of rust
Now there is nowhere for the bracket to go and the pump is held on with 3 cable ties
Has anyone elses bracket rusted away? and if so, what did you do? i can't see anyone wanting to buy a car that's as DIYd as that
Oh the joys
Old Apr 3, 2005 | 06:47 AM
You can get the bracket and the fixings from ford still ,replaced mine when i did me under body
Old Apr 3, 2005 | 06:51 AM
The big bracket comes with the large rubbers on ,the fixings to the car are bolts that go through the boot floor(stuck down to it )and the brackets bolted on ,hope this helps ,expecy to pay £30-£40.
Old Apr 3, 2005 | 07:59 PM
kevsrs's Avatar
kevsrs
Top work twins, thanks a lot
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
