tracking settings
Old Apr 20, 2015 | 10:37 AM
RUBY123's Avatar
RUBY123
Default tracking settings
Hello has anyone got any tracking settings for a escort turbo they have tried ive looked online and found the group a s1 settings i think but thats about it
Old Apr 20, 2015 | 05:59 PM
Marc D's Avatar
Marc D
Either parallel or slight toe out
Old Apr 20, 2015 | 06:18 PM
s2erst's Avatar
s2erst
Yes its 2neg +or-1
Old Apr 20, 2015 | 06:51 PM
RobedST24's Avatar
RobedST24
Old Apr 20, 2015 | 09:11 PM
moesin2005's Avatar
moesin2005
where do you get the auto data program
Old Apr 20, 2015 | 09:44 PM
RobedST24's Avatar
RobedST24
I've got a copy mate but only does upto 2004
Old Apr 20, 2015 | 10:47 PM
moesin2005's Avatar
moesin2005
I have upto 2005 but only works on xp
Old Apr 21, 2015 | 06:49 PM
RobedST24's Avatar
RobedST24
Yer the same as mine only works on Xp down graded my vista laptop to run it
Old Apr 22, 2015 | 05:55 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
that will make it drive awful where did you get that info
toe in 2degree for quick turning less high speed. or little less for straight line.
without decent rollbar and tie bars it will be naff what ever you do.
ideally you want to copy my settings that I made up for 3 different uses. but you will need better parts fitted.
Old Apr 23, 2015 | 10:16 PM
Si74's Avatar
Si74
Any pointers on the rear as I've just fitted adjustable tie bars.
Old Apr 26, 2015 | 08:50 AM
Versus_Creations
Ask me a question!
adjustable rear tie bars are pointless without being able to adjust it all.
if you adjust caster it will effect toe and camber. cant adjust one without the other.
all you can do is make the best of it so pointless giving settings as you wont be able to get them anyway.
Old Apr 27, 2015 | 12:31 AM
Si74's Avatar
Si74
Eh, surely it makes it easier to replicate Fords total f--k up then than having to take it all apart to add or subtract washers.
Surely a tad more constructive to say point them in a bit or dead ahead than the usual no point in telling the muppets anything
Old Apr 27, 2015 | 01:12 PM
Cawood's Avatar
Cawood
Versus - where can we see details on your 3 different settings?
I need to get mine setup as it drives & handles crap at the mo
I have
MEF motorsport adjustable TCA's
fully Polybushed
front strutbrace
that sufficient?
its just a fast road car
Thanks mate
Old Apr 29, 2015 | 09:24 PM
Marc D's Avatar
Marc D
I've always thought fwd cars had a tiny bit of toe out and that toe out gives you better turn in whereas toe in gives you more straight line stability?
Old May 1, 2015 | 06:48 AM
Versus_Creations
Ask me a question!
if you toe out... when you put power down they will toe out even more.
if they toe in. when you put power down the wheels end up flat.
meaning most rubber on road.
my guides are available but I cant posts links to my site as im not a trader so you need to find them yourself or ask someone for a link.
Old May 2, 2015 | 01:02 AM
foci18's Avatar
foci18
Oddkiddcreations.co.uk
Old May 6, 2015 | 06:31 AM
Chas's Avatar
Chas
What are the recommended toe, camber and caster all around the car?
Old May 7, 2015 | 06:31 PM
Chas's Avatar
Chas
This is what I have understood with any FWD car I have owned. Upon accelerating the front wheels are meant to toe in, or barely toe in if running on nylon bushes/ball bearings. I understood that RWD cars had their front wheels toe out slightly when on the move. I can see more toe in potentially reducing torque steer but also accelerating tyre wear on the outside of the tyres.
ossie cossie
57
Nov 21, 2022 10:05 AM
yatta
May 21, 2016 10:31 PM
Adam Graham
Sep 6, 2015 06:04 AM
turbowag
Sep 3, 2015 08:07 AM
Cragrat
Sep 2, 2015 08:25 PM
