Zetec turbo problems
Old Apr 18, 2015 | 01:57 AM
westfieldturbo's Avatar
westfieldturbo
Default Zetec turbo problems
Got a bit off a prob with my Westfield zetec silvertop turbo it's all mapped and up and running and going well but there's one problem it seems to have extramly slow throttle response not just when driving but even at idle ! You can actually see it in the boost gadge at idle floor the thottle and boost gadge looses vacuum then revs a sec later and I mean a second literally the ECU is a old e48 DTA mapped off a very reputable mapper and very happy with the map ! So not sure if this is a problem with an actual car part or more a mapping issue ! Any ideas very welcome
Old Apr 18, 2015 | 06:17 PM
studabear's Avatar
studabear
What inlet are you using on this?
Old Apr 18, 2015 | 06:23 PM
westfieldturbo
It's a griffin inlet or a least a copy of one
Old Apr 18, 2015 | 09:51 PM
nevsrevs's Avatar
nevsrevs
What does the boost gauge do when your driving and you get lazy throttle response?
Old Apr 18, 2015 | 10:24 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
How can it be mapped well if it has this problem?!
Any issues with the setup need to be sorted before mapping, throttle response is part of a good map.
Are you sure you don't have a boost leak?
What boost pressure are you seeing at full boost? Did you managed to drive it? how does it drive when on boost?
Old Apr 18, 2015 | 10:40 PM
westfieldturbo
Only boosting at 5.5 psi and yeh driving very well apart from this problem with the throttle response dint think there's a boost leak but to be honest can't see how that would cause my problem though
Old Apr 18, 2015 | 11:12 PM
zetecbeast's Avatar
zetecbeast
Under the car...!
5.5psi? how is that set? is a spring in wastegate or EBC or something? What boost should you be seeing? eg/ what was the mapper expecting?
My current silvertop turbo boost's ten psi and it is not a built engine. 5 psi seems really low.
Old Apr 18, 2015 | 11:16 PM
westfieldturbo
Boost is controlled via external wastgate
Old Apr 18, 2015 | 11:17 PM
westfieldturbo
Old Apr 19, 2015 | 07:06 AM
nevsrevs's Avatar
nevsrevs
Can you explain better wat is happing? Does it do it all the time, or some times.
Old Apr 19, 2015 | 07:31 AM
westfieldturbo
All the time like there's a 1 sec delay when I hit the throttle
Old Apr 19, 2015 | 08:44 AM
zetecbeast's Avatar
zetecbeast
Under the car...!
150hp is about 100 hp off what a good zetec turbo can dyno on stock bottom end.
I think you need another person to look at the engine map. It isn't ready to remap if there is an issue with its running so it shouldn't have been mapped till it was fixed..
If there wasn't an issue with the running before mapping then it is possibly down to the mapping..
Old Apr 19, 2015 | 09:17 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
No acceleration enrichments or too much, poorly map or tps sensor, air leak on manifold after throttle body.
Or just crap mapping, that boost is very low for the potential by a big margin.
Old Apr 19, 2015 | 10:17 AM
zetecbeast's Avatar
zetecbeast
Under the car...!
18psi at 5,000rpm though.. is this a stock engine? what is the engine spec?
Just seen on the Dyno chart 155 (205.8) so I am guessing it is corrected to flywheel hp in the bracketes? (what dyno was it by the way?)
Old Apr 19, 2015 | 10:26 AM
Churtz's Avatar
Churtz
As above... sounds like a mapping issue and I would bet that the accell enrichments are incorrect. That is what they do... provide the correct fueling for the initial blip of the throttle....After that the normal map will take over again. Would give the exact symptom you have.
Matt.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
