traction control light on = mot fail?
Old Apr 16, 2015 | 12:05 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default traction control light on = mot fail?
Need to know as the Mondeo is going for the test so should I save my money?
Old Apr 16, 2015 | 01:00 PM
StephenC's Avatar
StephenC
..BS Motorsport..
http://www.motuk.co.uk/manual_340.htm
Could be if they're keen!
Old Apr 16, 2015 | 01:02 PM
dojj's Avatar
dojj
bollocks
Old Apr 16, 2015 | 01:50 PM
Caddyshack's Avatar
Caddyshack
Yeah, I heard they are really on this now but cannot be too hard to pull the bulb can it? Or clear the fault codes and see if it comes back...I am sure if you google "mondeo tranction control light" there will be a fix for the true problem (could just be a cheap wheel speed sensor) OR how to avoid it on the MOT.
Old Apr 16, 2015 | 02:16 PM
dojj's Avatar
dojj
I had to change the clocks because the speedo display LCD thing packed up
I "could" remove the bulb but it's an led in the circuit board which means lots of fiddlyfucking about to get the dials lines up and trued up again
And it's not got an mot so I can't be doing calibrating in the road either
Ducking cars
Old Apr 16, 2015 | 02:18 PM
Caddyshack's Avatar
Caddyshack
If you are based near enough to Pinner I can put you in touch with a straight but friendly MOT tester who will not be over the top.
Old Apr 16, 2015 | 03:24 PM
dojj's Avatar
dojj
The guy I use is pretty good and always tells me about stuff I need to do and stuff that needs to be done so I'm sure things week be fine at the end of the day but it's just so infuriating that fixing one thing dominos into something else needing to be fixed
Old Apr 16, 2015 | 06:49 PM
bigdel's Avatar
bigdel
could you not take the clocks out, to get to the LED and stick a bit of thick tape over it, then put it all back together again. A bit gash, but might work...
Old Apr 16, 2015 | 08:20 PM
dojj's Avatar
dojj
The dials need to come off before you can get to the led
I'm going to take it and see what happens, the worst thing if that it'll fail
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
