Gearbox oil leak MT75 4wd
Not really
I know where the drain plugs and the full holes are....the frekin transfer box output to front prop is weaping after a new seal as well
Swear I'm gonna burn this car before the year is out
give me a day or so and i'll get my book out to see what's supposed to go there
i've also got that part of the box so i can see for myself, but the breather is a torx bolt with a hole in it at the top of the box somewhere
might be the breather for the transfer box though
Thanks Glenn, as Dojj said, the pics are of the main casing, the hole is in the transfer casing just behind.
I did have a weap out of the front prop, which has since cleared, so it's ok now or its got no oil left in it
its a hole that was only used for production, (milling and mounting in the mt75 rig) if it is leaking from there then the oil seal inside the box is knackered as that seals it
TPM961
Jan 15, 2018 10:50 AM
Adam Graham
Sep 6, 2015 06:04 AM
