Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
car struggling starting in morning +
Old Apr 5, 2015 | 09:06 PM
marcussmoothy's Avatar
marcussmoothy
Default car struggling starting in morning +
Hi guys thank you for letting me join
I have recently bought a 1.8 focus 130000 miles on clock well serviced or so I believe 2004
Following fault codes p0251 p0401
Following problems
First problem: Glow plug light turns on for 1 second causing it hard to start in morning if I manual hold a wire from possible off battery to glow plug harness and heat them up manually it starts fine
Second problem: glow light comes on and car cuts out restart car and it's fine but I noticed it mostly does it if I put my foot down in a high gear like if I slow down to 50 on motoway and put my foot down in 5th gear
Thank you hope this can be fixed
JoeyBoyden
Jan 4, 2024 02:36 PM
liam-rst
Aug 10, 2015 08:46 AM
sridgett
15
Aug 3, 2015 07:26 PM
TommysKeeper
Shows & Track Days
Aug 1, 2015 12:59 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
