General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
So im building a 'budget' zetec turbo in my mk3 fiesta. Well i say budget, it owes me 6 grand so far.
I bought a 2.0 blacktop inlet manifold and a set of Focus RS injectors, went to fit it to the engine but the manifold is too big and wont fit between the head and the bulkhead of the car!
I found this on ebay, the bloke said i can use the focus injectors but has no fuel rail or anything with it?
None of them bolt straight on mate . I used to to cut the flange off and weld a zetec one on .ports line up fine and they flow well any bosch injector will fit
I used the n/a from an 820, it had a larger plenum than the turbo one.
I can post pics of both the injection and the turbo inlet and there is no difference. There's is a very early one that is bigger and has a alloy fuel rail but you will struggle to find one today
It was an early one with alloy rail. The same as what Ian first used after junking his throttle bodies, although he reversed the plenum as he had room.
Getting on for 20 yrs ago now when a zt was a new concept.
