-31 actuator
Old Apr 2, 2015 | 10:36 AM
RUBY123's Avatar
RUBY123
Default -31 actuator
How stiff should a -31 wastegate actuator be to pull over the pin.
I fitted a brand new one months ago but just got round to playing with the boost control i originally fitted it half a hole but pumped it up with a pump to slide it over the pin. It was only holding 6 psi so wound it in more recently and it pulls over easy just by hand every other one ive had you have to play tug of war with it lol.
Old Apr 2, 2015 | 07:22 PM
What cars is it fitted too.
Old Apr 2, 2015 | 11:18 PM
RUBY123's Avatar
RUBY123
its on a cosworth t3
Old Apr 3, 2015 | 07:26 AM
gcfcos's Avatar
gcfcos
Gftjkmvfhkn b
Old Apr 3, 2015 | 07:55 AM
RUBY123's Avatar
RUBY123
Old Apr 3, 2015 | 08:59 AM
Cossy Mike's Avatar
Cossy Mike
Should be really stiff are you sure its a genuine -31?
Old Apr 3, 2015 | 09:19 AM
gcfcos's Avatar
gcfcos
Originally Posted by RUBY123
Sorry was gonna reply but nipper got hold of my phone!
Old Apr 3, 2015 | 09:42 AM
RUBY123's Avatar
RUBY123
Thought is was secret code lol
Old Apr 3, 2015 | 09:43 AM
RUBY123's Avatar
RUBY123
Its what ever msd sell will take it off when the rain stops and take a look
Old Apr 3, 2015 | 09:58 AM
Stu @ M Developments's Avatar
PassionFords Creator
A -31 lifts at 8psi with correct pre loading can be loaded safely to around 6mm.
Sounds like your boost control may have a problem as with the waste gate loaded to 8 the engine will typically receive about 6.
Old Apr 3, 2015 | 10:50 AM
RUBY123's Avatar
RUBY123
Half hole pre load it boosts around 5 psi with boost control turned off over a full hole pre load boosts around 7 psi and it slides over the pin easy with one had will try the old one again that one never had that problem
Old Apr 4, 2015 | 08:53 AM
RUBY123's Avatar
RUBY123
all fixed put the old one back on it seems the spring was weak in the new one
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
