rpm very slow to fall on over run after cleaning throttle body
Old Mar 31, 2015 | 09:18 PM
fww's Avatar
fww
Default rpm very slow to fall on over run after cleaning throttle body
could you please help after cleaning the throttle body on my st150 fiesta the idle rpm is 2000 for 5 seconds then back to 900 .when in top gear it will not fall below 1100. when clutch is pressed at junctions revs rise to 2500 for about 5 to 10 secs then back to 900 .it all checks out on diagnostics
Old Mar 31, 2015 | 09:39 PM
frsjon's Avatar
frsjon
when you say clean it did you take it off? sounds like a air leak...or throttle position sensor problem
RichieST's Avatar
RichieST
You've probably removed the coating off the inside of the throttle body thus causing an air leak past the butterfly. You should never clean them unless the butterfly is sticking open.
Dicko&Vacant
Aug 21, 2015 05:59 PM
Bailes1992
Aug 16, 2015 07:14 PM
nick8saff
Aug 16, 2015 05:35 PM
M K
Aug 12, 2015 06:57 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
