What's the best mod you have
Mar 29, 2015 | 08:26 PM
I'm looking to do a few bits to my 4x4 saph cosworth over the next few months.
What's the best mod you have done. I'm not building a race car and I'm hoping to keep it a fairly nice road car it's 400 hp as it is.
I'm think Hyd clutch is it worth doing?
Mar 29, 2015 | 08:45 PM
Closed loop.and wasted spark
Poly diff mount.
Mar 29, 2015 | 08:46 PM
Vipec ecu with coil on plug.
Had clutch is easy n worth doing
Mar 29, 2015 | 09:52 PM
Straight cut box as your standard one will go bang soon
Mar 29, 2015 | 10:15 PM
As a £££ vs performance benefit, without a doubt the uprated diff mount and solid beam mounts
Mar 30, 2015 | 06:17 AM
Brakes, adjustable beam, diff mount.
Mar 30, 2015 | 07:48 AM
Quote:
Originally Posted by
costina
Poly diff mount.
Agreed already on her when I got the car
Mar 30, 2015 | 07:49 AM
Paul_RS
I've got a management change in mind but not until next year. And I was thinking I need a new box There can't be much left in mine
Mar 30, 2015 | 07:50 AM
dissmalrs
The hydraulic clutch conversion makes a big difference, one of the best things you can do.
Apr 1, 2015 | 07:17 AM
NMS Live map
6 degree beam
Apr 1, 2015 | 07:58 AM
New engine loom with all new sensors and a L8 closed loop & Anti-lag setup.
The loom and new sensors transformed the smoothness of the engine and the anti lag is just the most fun ever!
Apr 1, 2015 | 08:33 AM
best mod on 4x4, remove front drive shafts
Apr 1, 2015 | 10:13 AM
Cos500
Best post so far lol
Apr 1, 2015 | 10:22 AM
Rear diff mount. 044 bosch fuel pump and modded wiring loom for both fuel pump and fans.
Apr 2, 2015 | 05:23 PM
Rear strut brace and diff mount has made a big improvement to how my 3dr drives. Money well spent.
Apr 2, 2015 | 07:32 PM
If you haven't got some decent brakes up front I'd invest in those, followed by a secs monitor or modern day equivalent to monitor the engine and a decent suspension set up; koni shocks and ahmed springs or coil overs
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
