Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
MK5 Festa won't start. Fuel system?
Old Mar 18, 2015 | 04:01 PM
poo_and_wee's Avatar
poo_and_wee
Default MK5 Festa won't start. Fuel system?
Hey Guys
A little help needed.
I have a 51 plate Fiesta with the Endura-E engine. I have just replaced an alternator on it because the old one seized and tried to set fire to the car. Because the battery is now a dirty white box with water in it I had to use my Mondeo TD to crank it over. She started but then immediately cut out and then refuses to start again. I filled it with a little fuel (£5) and then tried again but to no avail. To test for a spark I used a strobe while cranking over. It strobed so I can only assume that it has a spark. I looked at the fuel pump and it’s cylindrical and dirty but other than that I have no idea how to proceed. I don’t know if it is working because I can’t see (or feel) where the damn terminals are. It could be that part of the injection system isn’t working. Is there a procedure to diagnose this issue further? I have checked the fuses by the way.
Thanks for reading. Hope you can shed some light on my predicament.
Fuel pump that I inspected was actually a fuel filter.
Last edited by poo_and_wee; Apr 1, 2015 at 01:41 PM. Reason: Fuel pump was a fuel filter - I'm stupid
Old Apr 1, 2015 | 01:39 PM
poo_and_wee
Default Update
So I change the fuel pump relay and a 10 amp fuse and the fuse keeps blowing. I read that someone with a similar problem had a blocked fuel filter but I have just changed mine and still blowing fuses. Trying to reset the ECU by clamping the battery leads together (without battery obviously) to clear all power but I don't think that will work. Perhaps it's the fuel pump which is what I am dreading as I don't want to have to drop the fuel tank on the driveway.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
rex647
Mar 6, 2022 06:20 AM
JK12
33
Apr 26, 2021 12:09 PM
fuzzy
Sep 4, 2015 10:11 PM
ST-170
Sep 4, 2015 11:02 AM
