Ford Racing Puma 481
For sale i have my racing puma no. 481/500 of around 300 remaining! These cars are getting rarer each year and will only go up in value as per all tickford built fords!
I have owned this car for two and a half years and its been absolutely fantastic, the only reason for sale is to fund my next project.
The car has covered 105k miles and was fully repainted two years ago.
Like all of these cars it has paint imperfections but is all round a clean car.
I have maintained this car regardless of cost (all work being carried out at cosworth/puma specialists supreme car services), along with doing suitable upgrades to make it all round better.
Here is a list of parts/upgrades done in the last 1000miles.
full gearbox rebuild including new bearings, seals, viscous limited slip differential.
Whilst the gearbox was out i fitted a new clutch release bearing and clutch.
The engine was removed at this point and given a full health check and paint to be like brand new along with fitting new cambelt and tension, camcover gasket, inlet manifold gaskets, exhaust manifold gasket, idle control valve, thermostat and stat housing.
When fitting the engine back in i fitted a new heater control valve as these usually break, and a new throttle cable.
Auxillary belt and pulley
Brand new alternator
New bonnet switch
Full engine service inc, oil filter, new gen ford oil, plugs, pollen filter, air filter is pipercross
As you can see in the pictures the engine bay looks great.
Interior is in fantastic condition, the two front seats cost me £700 and when fitted had brand new racing puma seat covers to protect them, so are in fantastic condition.
The usual worn puma wheel was replaced with a sparco 350mm suede wheel. (Comes with original needing retrim)
Jvc head unit/cd player.
Rear beam has been poly bushed using powerflex bushes.
Full miltek exhaust system
yokohama parada spec 2 tyres
Hid headlight conversion (one of the best mods to do!)
New genuine ford front splitter
The car will come with the private ford racing puma (frp) number plate (FRP 86L)
The car has just had the original wheels fully refurbished and new centre caps made, the Alcon brakes have also just been refurbished.
Im genuinely gutted to see it go, and it will be a great car for someone, particularly as this year it is the 15th anniversary and the new owner will be welcomed along to the two gatherings!
Price is £5800 ono
Ryan Gibbs
07907548809
New bonnet switch
Price is £5800 ono
Ryan Gibbs
07907548809
borboyous
Aug 22, 2015 11:17 AM
