Bottom ball joint bolt/nut
Old Mar 14, 2015 | 07:34 PM
Prickly_buzz's Avatar
Prickly_buzz
Default Bottom ball joint bolt/nut
Right ive had a mare today with my sisters street ka, it was pulling all over the road as you accelerated and lifted off.
I found both bushes in the nearisde lower arm where completely nakard, so i removed the arm, killed the ball joint bolt in the process but thought it wasnt an issue as i had a new nut and bolt to go in, at least i would have done if i was sent it....so i have refitted everything minus the nut and bolt.
My question is where can i get a nut and bolt which will be ok for tomorrow as she needs the motor desperately on Monday and i go back home tomorrow and wont be back for a week! HELP!
P.S ive found the bolt is M10x1.5 49 mm long
Old Mar 14, 2015 | 07:52 PM
Prickly_buzz
Would these be man enough - http://www.diy.com/departments/10mm-.../237523_BQ.prd
I know they are slightly longer but that shouldnt cuase any issues.
Old Mar 14, 2015 | 07:59 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
I wouldn't use the B&Q bolt as it will be low grade. You'll want at least an 8.8 high tensile bolt, preferably a 10.9. You can get them from a local Engineering fastener company.
Old Mar 14, 2015 | 08:05 PM
Prickly_buzz
I think best bet is tell her tough and i will get the proper nut and bolt from Fords.
What about tourque settings, at the moment ive done the bolts up 'sensibly tight' lol
Old Mar 14, 2015 | 08:24 PM
bagginsRSturbo's Avatar
bagginsRSturbo
If you have a toolstation near you they sell high tensile bolts
Old Mar 14, 2015 | 08:39 PM
Prickly_buzz
Yea, i have not a bad idea. Might get over there tomorrow, looks like they sell 70 mm long bolts but that will have to do. They also sell locking nuts too.
Old Mar 14, 2015 | 09:17 PM
studabear's Avatar
studabear
halfords or a decent motor factors will probably stock them.
Old Mar 17, 2015 | 11:46 AM
LewisT's Avatar
LewisT
had the same problem on my focus years ago slap some molybdenum or copper grease on the shank of the bolt they will tap out easily in the future
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
martynhomer01
14
Sep 23, 2015 12:23 AM
