Zetec turbo wastgate problems
Old Mar 3, 2015 | 01:48 PM
westfieldturbo's Avatar
westfieldturbo
Default Zetec turbo wastgate problems
Iv got a problem with my wastgate its a cheepo type I think I dident buy it new no names stamped into it the manifold is SPA and then I go on to the SPA ate they sell a wastgate that looks just like mine so probs is a SPA gate as well the prob iv got is the actual vale in the gate actually seals onto the manifold itself but neither are totally flat it's ment to have a 7 psi spring in it but to get the valve to seal on the manifold property I have to tighten the spring to the extent of it boosting at 11psi to much for my engine . So what I'm wondering is do some wastgates that seal within there selfies rather than relying on the seal between the valve and manifold?
Old Mar 20, 2015 | 10:07 AM
stevieturbo's Avatar
stevieturbo
C**t
Speak english, or post some pictures of what you are trying to describe.
And if something isnt flat, make it flat.
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
