Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
2001 1.6 zetec at a loss with idle / slow rev drop
Old Feb 25, 2015 | 09:00 PM
Steven eley's Avatar
Steven eley
Unhappy 2001 1.6 zetec at a loss with idle / slow rev drop
Hello i brought my focus about a month ago
Intemittently the car will when changing gear hold the revs Where They were eg 2000 for a second then drop
slowly, also when comming to a stop it will be ideling at 800 as normal then rais to 1100 as i stop for a moment
with an odd popping from air filter box?
And other times will be seemingly fine i have no fault
codes and i sprayed easy start about the inlet/vaccume
and cleand the idle control
Hope for some advice guys thank you for your time
Old Feb 27, 2015 | 02:52 AM
Neilfi's Avatar
Neilfi
Could be the air flow sensor. Or more likely the speed sensor, they're the cause of many running problems, as they send info to the computer, and they tend to get fouled by the elements (and are a bugger to remove/refit, have to do it from under the car).
TPM961
Jan 15, 2018 10:50 AM
focuspower
Sep 19, 2015 08:27 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
