Ka leaking thermostat housing.
Hi all...my daughters 04 KA 1.3 duratec engine has a leaking thermostat housing...the plastic type.
I fiited a new one 2 years ago...now its leaking again.
Ordered a new one...stripped it down today to find the old one looked find...O ring intact...but some corrosion on the mating face on the head where the housing bolts to.
This is spoiling the flat mating siurface....I have scraped it clean...at its worse the corosion is about 1mm deep...I have thought about smearing RTV silicon on to take up the gap.
Any ideas guys.
Its had Ford type anti freeze in from new.
Nick.
Any ideas guys.
Nick.
I could never get silicone gasket to seal tidy on the other halfs KA.
Ended up spending an hour with some fine sand paper until I got the head super smooth and than fitted a new housing and gasket.
Use multi purpose grease on the rubber o ring prior to re fitting housing. Old mechanics trick
obviously after getting the mating surface clean and flat.
Maybe use chemical metal to fill in the imperfections and sand it down flat when it's dried? I'm just assuming the corrosion has eaten into the head and left an indent?
Yeah I think if it was me and it's clean but with indents rather than taking the head off I'd try filling the indents with chemical metal and then sanding it back down flat. If that works then at least you've saved yourself a heap of work, if not then at least u tried. What engine is in your kA?
The Enigma
Sep 29, 2015 10:31 AM
