Sytec fuel pumps v Bosch 044
Old Feb 13, 2015 | 06:44 PM
benw456's Avatar
benw456
Default Sytec fuel pumps v Bosch 044
I'm looking for any information about the differences between the 2 pumps.
Has anyone used or using a sytec one? Are they ok as there is a big price difference between the two.
Any help appreciated as always!
Old Feb 13, 2015 | 06:51 PM
Caddyshack's Avatar
Caddyshack
I think this is the one Mark Shead rates (system)
Old Feb 13, 2015 | 07:03 PM
Mark Shead's Avatar
Mark Shead
What's it for.
Mark
Old Feb 13, 2015 | 07:45 PM
benw456's Avatar
benw456
It's for a Sierra cosworth running a t35, greens, 3 bar etc.
Old Feb 13, 2015 | 07:48 PM
Mark Shead's Avatar
Mark Shead
A 044 is fine, a DW350IL is the same fitment but flows about 20% more than a 044 but that's prob a bit much for what you are wanting,
I have not tried a Syntec 044 style fitment to be able to comment on that, I use there 450 version for fitment in the Evo or Escort cosworth.
Mark
Old Feb 13, 2015 | 07:49 PM
benw456's Avatar
benw456
Cheers mark, I'll probably go for the 044.
Old Feb 13, 2015 | 10:50 PM
Jay,'s Avatar
Jay,
Sponsor
Got one on my cossie its great
Old Feb 17, 2015 | 04:12 PM
stevieturbo's Avatar
stevieturbo
C**t
Sytec also sell 044's
So exactly what pumps are you comparing ? And have you asked Sytec ?
Old Feb 17, 2015 | 04:25 PM
stevieturbo
C**t
Mark
How does the DW cope at pressure ? 044 seems to be the only pump out there ( compared to Walbro types ) that keeps flowing over 75-80psi where most others fall flat on their faces.
Current draw ?
At 40psi most flow tests for an 044 seem to be in the 300-330 lph range, not that anyone ever runs a boosted setup as low as 40psi in real load conditions.
edit, found this. They state the pumps are competition use only...are they reliable enough to use on the road ?
http://www.deatschwerks.com/resource...el-pump-tech-2
AMS 044 vs older Walbro ( not sure what their modified Walbro is...it seems to massively outflow a normal version )
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
