Fuel flow rate
Old Feb 13, 2015 | 04:15 PM
jay030787's Avatar
jay030787
Default Fuel flow rate
Hi can anyone tell me what the flow rate is for an escort on cosworth management or a Sierra cosworth
Old Feb 13, 2015 | 05:02 PM
little bram's Avatar
little bram
Try asking jano OKC he'll tell you. I think it's 2bar and 2.5 with reg pipe off best ask jano tho.
Old Feb 14, 2015 | 08:11 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
I did tell him via txt
3bar at idle wih vac
3.5bar at idle without vac
Old Feb 14, 2015 | 02:09 PM
little bram
Dam was a bar out Knew it was something close to that good job I said to ask.
Old Feb 14, 2015 | 02:12 PM
jay030787's Avatar
jay030787
That's fine I no what pressure it should be but isn't there an amount of fuel over an amount of time ? I was told you can have pressure but not quantity
Old Feb 17, 2015 | 10:22 AM
Karlos G's Avatar
Karlos G
Balls Deep!
That's correct, flow and pressure are two different things... Almost any pump will hold pressure at idle, but that doesn't mean it will flow enough to hold that same pressure at full load for example.
I'm not exactly sure what you are asking but if you have chosen a fuel pump capable of flowing for your desired BHP and your fuel pressure is set correct for your injectors and map you should be fine.
Old Feb 17, 2015 | 11:27 AM
jay030787's Avatar
jay030787
Thanks for that I just got a cheep pump off eBay for £30 so I will have to get a better pump that's probely half my problem
Old Feb 17, 2015 | 12:50 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Could be! lol
Old Feb 17, 2015 | 03:24 PM
jay030787's Avatar
jay030787
Ok will get a genuine bosch one tonight
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 29, 2015 11:27 AM
