Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Help with replacing original mk2 stereo
Old Feb 13, 2015 | 03:05 PM
Danielchristian's Avatar
Danielchristian
Question Help with replacing original mk2 stereo
Hi guys,
Can someone please explains me how to remove the original stereo from the dash on my 1985 mk2 fiesta?
I can't see any pins on the stereo where you would normally insert the removal keys - the guy at halfords said it would be a case of removing some of the screws in the dash to get it out. Any tips/pictures would be much appreciated!
If it helps the stereo is on the bottom part of the dash - ie. Just in front of the base of the gear knob. It is the factory fitted radio only stereo.
Finally, I am also looking to locate a stealth shelf for my new speakers as I don't want to bugger the original parcel shelf if possible.
Many thanks,
Dan
Old Feb 15, 2015 | 04:02 PM
BobbyTaylor93's Avatar
BobbyTaylor93
I'm having the same thoughts haha I've got a 1985 1.1 dash model and it's got the same radio as you by the sounds of it haha gonna investigate soon, do you know what wiring adapter we need?
Old Feb 22, 2015 | 06:04 PM
minder's Avatar
minder
all you need to do mate is use a flat blade screw driver
and gently prize it out as for the shelf just replace it
with your new one
Old Mar 5, 2015 | 04:12 PM
Adam592's Avatar
Adam592
Sounds similar to my one.
If you remove the volume/tuner dials there are some bolts you need to undo.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
gingeRS
Sep 4, 2015 06:29 PM
hopper350
Sep 4, 2015 12:53 AM
