Saph cos fuel pipe nightmare :-(
Old Feb 6, 2015 | 03:52 PM
gcfcos's Avatar
gcfcos
Default Saph cos fuel pipe nightmare :-(
Afternoon guys! Well what a nightmare today turned out to be. Booked half day holiday to get the old saph cos 4x4 on the ramp to attack the growing to do list. Thought I'd start with changing the fuel filter as long time overdue (typical mechanics car!) fitted the new genuine ford one with new copper seals and the bugger leaked. Took it all apart again, cleaned up the banjo unions, re fitted with more new seals and leaking again! Tried the old filter back on with old seals and still leaking. It's only a weep at both unions but still leaking all the same. Looks like I may have to get new fuel pipes or buy some fuel banjos I've seen on eBay and replace the plastic pipes with rubber fuel hose. Has anyone come across this problem before? Inputs much appreciated! Thanks
Old Feb 6, 2015 | 04:26 PM
I had the exact same problem. It was just weeping out. Tbh i haven't noticed it dripping anymore. Next time i start the cossie up i will have to check it.
Some peeps on here said use the washers with the rubber bit in the middle. I cant remember what there called.
Old Feb 6, 2015 | 04:39 PM
gcfcos's Avatar
gcfcos
Originally Posted by Glenn_
I had the exact same problem. It was just weeping out. Tbh i haven't noticed it dripping anymore. Next time i start the cossie up i will have to check it. Some peeps on here said use the washers with the rubber bit in the middle. I cant remember what there called.
Cheers for the reply mate. It's pissed me off so much lol, what was supposed to be a quick job to start a good afternoon of tinkering off turned to shit! Yeah I know the washers u mean, I found a few in my toolbox but they were too big, bloody typical! :-(
Old Feb 6, 2015 | 04:41 PM
gcfcos's Avatar
gcfcos
Do u not use yours as a daily anymore matey? Only ask as I seem to remember saying u did before? Bloody cars lol
Old Feb 6, 2015 | 04:43 PM
anglia105e hinson's Avatar
anglia105e hinson
Dowty seals are what you need mate !
There a washer with a rubber/viton bit inside .
I use them on mine . Have a look on eBay .
I get them at work .
Old Feb 6, 2015 | 04:46 PM
gcfcos's Avatar
gcfcos
Originally Posted by anglia105e hinson
Dowty seals are what you need mate ! There a washer with a rubber/viton bit inside . I use them on mine . Have a look on eBay . I get them at work .
Cool thanks mate never knew what they were called lol! Just being annoying but does anyone know what size ones I will need? Cars back together now to get me home and can't undo the banjos again as I need to get it back to work to fix the bugger :-( thanks again
Old Feb 6, 2015 | 05:00 PM
anglia105e hinson
Can't remember mate either m12 or m14 thread banjos , might be worth a Google lol
Old Feb 6, 2015 | 05:30 PM
gcfcos's Avatar
gcfcos
Just checked on Matt Lewis website, m14 banjo bolts they are, so I'll be on the lookout for some m14 dowty washers. I'll let u know how I get on. Thanks a lot for your help, much appreciated!
Old Feb 6, 2015 | 05:31 PM
James @ M Developments.'s Avatar
You do have to do them up really tight to seal,
Old Feb 6, 2015 | 05:59 PM
gcfcos's Avatar
gcfcos
What the dowty ones?
Old Feb 6, 2015 | 06:05 PM
stevos's Avatar
stevos
You could try and heat the copper washers with a burner until they go Cherry red this makes them a bit softer and easier to crush.
Old Feb 6, 2015 | 06:21 PM
No the copper ones, if they leak nip them up again and normally you can get them to seal
Old Feb 6, 2015 | 06:33 PM
s1cosse's Avatar
s1cosse
Forget all cooper washers I had the same problem doing merk fuel filters at work. I started using alloy washes after that never had a pro it's the way to go.
Old Feb 6, 2015 | 07:09 PM
gcfcos's Avatar
gcfcos
I pretty much tried all the copper washers in our wurth selection box at work, did them up proper tight, even tightened them nearly hanging off the spanners with the other mechanic at work all to no avail :-( tried alloy sump plug washers and that didn't work. Gotta be the dowty ones next to try methinks
Old Feb 6, 2015 | 07:10 PM
gcfcos's Avatar
gcfcos
I did notice on the original filter the inner washers were slightly smaller than the outer ones to seal on the slight cut out bit on the genuine filter
Old Feb 6, 2015 | 08:16 PM
botters's Avatar
botters
competant bodger
i find the opposite dont tighten them up to much! i always rub the washers on a some sandpaper on a flat surface then heat them up cherry red, allow to cool and then just nip them up
Old Feb 6, 2015 | 08:21 PM
3i Jim's Avatar
3i Jim
10 Year Member
Errr, red hot washer + open fuel line =
Old Feb 6, 2015 | 09:05 PM
stevos's Avatar
stevos
Default I'm
Obviously you hear the washer and let it cool before putting it near the fuel filter. The process is called annealing and makes the copper softer and more likely to seal an not stupid smart arse.
Old Feb 6, 2015 | 09:12 PM
botters's Avatar
botters
competant bodger
dont worry pal some people are just retards!
Old Feb 6, 2015 | 09:19 PM
3i Jim's Avatar
3i Jim
10 Year Member
Sorry my bad, but word it a bit better next time
Old Feb 6, 2015 | 10:32 PM
anglia105e hinson
I would say forget the copper washers and use dowty seals. I've always and the same problem and just end up swapping them for dowty.
Nothing wrong with the normal copper ones just prefer IMO
Luke
Old Feb 7, 2015 | 07:36 AM
gcfcos's Avatar
gcfcos
I'm gonna go to screw fix this afternoon for some m14 dowty washers and fit them in the week, I'll let u know how I get on if this doesn't work does anyone or has anyone replaced the plastic pipes with rubber ones before? I see the one from the filter goes to a metal pipe.
Old Feb 7, 2015 | 05:16 PM
gcfcos's Avatar
gcfcos
Well managed to find time to fit the two dowty washers that I had, that side of the fuel filter is now sealed up a treat! Result! Just ordered 2 more off eBay
Old Feb 7, 2015 | 05:46 PM
Not no more matey. Ive got a Ford pooma that i use as my daily. All the money ive spent on body work i dont want the bastard rusting again lol.
Old Feb 7, 2015 | 05:51 PM
Cool. I was just about to offer you some that ive got. Im sure i tried them washers and they didnt seal.
Old Feb 7, 2015 | 06:13 PM
Fil's Avatar
Fil
ELASTIC BAND
will renew my fuel filter in the next few weeks, ill get a few dowty washers ready before i start the job now
Old Feb 7, 2015 | 08:45 PM
gcfcos's Avatar
gcfcos
Yeah prob a good plan. I ordered a couple more off eBay and then my mate who's a bus mechanic says he has shit loads at work and he's gonna pinch me some for next time lol
Old Feb 7, 2015 | 08:50 PM
gcfcos's Avatar
gcfcos
Fair play mate, I think my ideas of using mine as a daily are long gone, got a 18month old nipper now and we just ordered a new car through work so no need to use the Cossie everyday now
Old Feb 7, 2015 | 08:51 PM
gcfcos's Avatar
gcfcos
Thanks matey
Old Feb 7, 2015 | 09:22 PM
RSCossieGaz's Avatar
RSCossieGaz
So is it the m14 dowty washers thats needed then? I think i will need to pick up a set for mine.
Old Feb 8, 2015 | 09:29 AM
gcfcos's Avatar
gcfcos
I used 2 dowty washers that I had in my toolbox that were actually old Peugeot sump plug washers lol! Only had 2 though so ordered a couple more through eBay and through my mate but yeah fitted them and the leak sealed straight up I'm bloody glad the cars not my daily driver or I would have been royally screwed!
Old Sep 1, 2015 | 03:27 PM
gcfcos's Avatar
gcfcos
still leak free and working a treat. Bloody good them doughty washers
cossie09
Sep 14, 2015 04:21 PM
JamesH
Sep 2, 2015 10:02 AM
jonjg
Sep 1, 2015 03:46 PM
155lee
14
Aug 22, 2015 12:15 PM
ray barker
Aug 7, 2015 09:00 AM
