3dr rocker gasket replace best way?
Old Feb 4, 2015 | 08:38 PM
tpaul's Avatar
tpaul
Default 3dr rocker gasket replace best way?
Hi Guys
Which is the best way to change the rc gasket and half moons to eliminate leaks?
Ive read various stuff
I was going to seal down half moons in corners and then just fit gasket.
However do i grease the half moons or do i put sealer on them and on the rc gasket itself. Any advice would be great.
Thanks Paul
Ps also where is the best place to get door membrane for a 3dr to ?
thanks
Old Feb 4, 2015 | 08:52 PM
cozzy jeff's Avatar
cozzy jeff
ive just sealed the ends of the half moon seals and fitted the gasket.
for the doors I used that sticky plastic that you use to protect your carpets/flooring when your decorating,available form screwfix.
Old Feb 4, 2015 | 10:56 PM
cossiestu's Avatar
cossiestu
Never had much joy with the paper gaskets, but now gone for a Cometic one, at least if that leaks, I can take it off and try again...
Old Feb 5, 2015 | 06:46 PM
gcfcos's Avatar
gcfcos
I put a very thin smear of blue hylomar onto the head just enough to hold the gasket down and small bit of hylomar at corners of half moon seals to seal them. That's with a paper/card cam cover gasket though, other types may not work like that?
Old Feb 5, 2015 | 07:43 PM
tpaul's Avatar
tpaul
thanks guys for the advice. Going to start putting engine back together next week
cheers
Paul
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Mark_
40
Oct 2, 2015 04:40 PM
muzzman1
Sep 30, 2015 08:59 PM
Brickhouse
Sep 23, 2015 06:28 AM
