Escos fuel pump
Old May 12, 2004 | 02:12 PM
Glenn5's Avatar
Glenn5
Default Escos fuel pump
Can 1 of u chaps tell me if i should upgrade my fuel pump before i chippin my large turb escos
Old May 12, 2004 | 02:23 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Depends on what stage chip you are going to be using. Stage 1 should be ok AFAIK but more than that i think you have to het an uprated one.
Old May 12, 2004 | 02:30 PM
Glenn5's Avatar
Glenn5
Well unsure at mo just brought a ggr grp a pump thinking of stg 1 4 now its just bit slow as std. ive got a set of greens and a 3bar left over from my last cos its so temptin 2 just buy a stage 3 chip and away we go again.
Old May 12, 2004 | 02:34 PM
CossieRich's Avatar
CossieRich
I would have thought a grp a fuel pump would be good enuff for stage 3. Did ggr not say what stage u could go up to with it? I think a stage 3 chip would be the way to go. Slow cossies arent any good are they.
Old May 12, 2004 | 03:41 PM
Glenn5's Avatar
Glenn5
I have slow cossie tho thats the prob unsure what 2do with her at mo shes only done 30k had 2 do an exhaust cus the standard 1 was shot so brought a mongoose and that ggr fuel pump they did say its suitable 4up 2 400ish but not 100% sure of that.
Old May 12, 2004 | 03:56 PM
Dave Henshall's Avatar
Dave Henshall
due to the age of the car and the fact the for 120 quid inc vat and delivery for the walbro 255l/h pump , is it worth even risking - the pump is a DIRECT replacement for the factory one, BUT shift about 4 times the amount of fuel.
got mine next day from http://www.fuelsystem.co.uk/ very helpful .
Old May 12, 2004 | 04:04 PM
Glenn5's Avatar
Glenn5
So is that better than the ggr grp a 1 the m8 cus i aint got a clue the ggr1 has arrived now so i mite stick it in 2nyt. and see how it goes only pain tho is dropping the tank and gettin dirty hands.
Old May 12, 2004 | 08:15 PM
Azrael's Avatar
Azrael
I am told that pumps from big Mercedes engines are great for the application. I have one from S500 or smth and it works fine.
Old May 12, 2004 | 10:44 PM
Glenn5's Avatar
Glenn5
Cheers m8 any tips on fitting it i know youve got 2 drop the tank and ive purchased a new o ring and locking ring
Old May 13, 2004 | 07:37 AM
Dave Henshall
if its not a lux - u can access the pump from the removable panel in the boot.
tip - use lots of wd-40 on all the bolts for the straps - i ened up having to angle grind them off and fit a new stud like in the hole as the tin plante that anchors the facotry nut snaps off cos its so rusty.
i believe the grp a GGR unit pumps 195 l/h and is a large unit that is twice the size of the std one, its actually one from a audi quatro - so ive been told
Old May 13, 2004 | 07:39 AM
Dave Henshall
ps, the walbro one is the same unit as i used in my 350 brake evo 6 as do most of the other peeps in evoland its good for around 500 brake.
Old May 13, 2004 | 10:13 AM
Glenn5's Avatar
Glenn5
Cheers m8 had better buy sum wd40 then mite just take her 2 local garage a get it sorted give sumbody else the hassle at least they cant mess the paintwork up if there underneath it just hope they dont smoke
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
Mickeystewart
Sep 9, 2015 04:04 PM
