Mercedes Vito CDI 111 Propshaft
Old Jan 24, 2015 | 10:33 PM
Harris.'s Avatar
Harris.
Default Mercedes Vito CDI 111 Propshaft
Hi, does anyone have some advise on how to check the above as from 30mph upwards my van now feels like im sitting on a washing machine .
Ive had all 4 tyres changed , common front anti roll bar bushes , all 4 wheel bearings checked but its still the same .
Ive heard the Vito suffers from Prop problems but not sure how to check it ? Not a ford I know but hoping someone will know
Old Jan 24, 2015 | 10:59 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
They are front wheel drive. They're known to eat driveshafts. There's likely to be play in the CV joints, outers get the hardest life. Get underneath it and try rotating the inner end of the shaft with the wheel locked. There should be almost no play in either inner or outer joint.
Old Jan 24, 2015 | 11:24 PM
Iain Mac's Avatar
Iain Mac
Vito hasn't been FWD for years!
The new one about to launch will have a choice of FWD with lower-powered 1.6engines. The current 2.1 engines will continue as RWD. The Europeans can also choose 4x4.
Old Jan 25, 2015 | 12:25 PM
Harris.'s Avatar
Harris.
Im not that stupid
Mine is a CDI 111 09 plate RWD .
Old Jan 25, 2015 | 12:27 PM
Harris.'s Avatar
Harris.
Originally Posted by Harris.
Im not that stupid
Ive been underneath and the prop does the norm twists left to right but under load im not sure how to test it .
Old Jan 25, 2015 | 05:20 PM
capri-rs's Avatar
capri-rs
have changed propshaft on a couple of vitos (4x4)
Stupidly expensive (4k+vat from merc stealership)
can change just the bearing (300£+vat)but will not be a lasting repair because of the universal joints are worn out and merc will not sell you new ones(at least not here in norway).
will see if i can find the part nr for the universal joints(buy mine from a tractor parts company) and the bearing.
Old Jan 25, 2015 | 08:30 PM
Harris.'s Avatar
Harris.
I can get a complete prop NEW FOR £350 still in the box but want to know its that before I get it or im wasting time/money
Old Jan 25, 2015 | 08:43 PM
Marcyg's Avatar
Marcyg
They're known for blowing the hell out the prop bearings. That price seems very cheap for a full prop, make sure it's a good part as if a uj or bearing lets go it's not pretty
Old Jan 25, 2015 | 08:52 PM
Harris.'s Avatar
Harris.
Ive seen it mate, totally new in the box .
Old Jan 25, 2015 | 09:17 PM
Marcyg's Avatar
Marcyg
Have a close look at the prop, make sure any balance weights havnt come loose etc. any idea where abouts the vibration is coming from
Old Jan 26, 2015 | 08:40 AM
Harris.'s Avatar
Harris.
Right up through the drivers seat, it gets worse the further you drive to a point now where I cant drive it .
Old Jan 26, 2015 | 09:20 AM
fraser9764's Avatar
fraser9764
had a transit once that one of the U shaped pieces of the UJ had opened up slightly. occasionally you would set off and it would vibrate violently up to 30mph or so then it would centralise itself and it would clear. It wasn't much and only really showed up when i took the prop off the van.
i actually managed to fix it by squeezing it back together in a vice. Ran for another 20k with no problems!
Old Jan 26, 2015 | 12:47 PM
Harris.'s Avatar
Harris.
Just got it back from the garage and inside the prop there is a rattle and there's a fair amount of movement is the prop bushes
IainRS1700T
Sep 25, 2015 06:44 AM
D1on
Sep 5, 2015 09:11 AM
fuzzy
Sep 4, 2015 10:11 PM
bassboy
Aug 8, 2015 10:21 AM
fuzzy
Jul 31, 2015 11:40 PM
