wet belt on a transit connect
Old Jan 24, 2015 | 10:23 AM
220tel's Avatar
220tel
Default wet belt on a transit connect
any one changed one of the wet belts on a 2011 transit connect, when mine goes in for a service and cam belt i would like to get this one done at the same time, but would have liked some info on times to change it etc. belt is a cassette type and around 90-00 to buy.
Old Feb 6, 2015 | 09:59 PM
220tel's Avatar
220tel
looks like nobody has been changing these, ford want £887-12p ffs
Old Feb 6, 2015 | 10:19 PM
Carlos-Titx's Avatar
Carlos-Titx
Something like 100,000 miles or 5 years on them.
Look on talk ford website to be sure but even dealerships skip them.
The 1.8 mkV mondeo has the same as well so could use that in your Google search for more info.
Old Feb 6, 2015 | 10:20 PM
Carlos-Titx
I think while the timing belt is done may as well get the wet belt done as well while it's all apart. Saves labour costs.
Old Feb 6, 2015 | 10:28 PM
220tel's Avatar
220tel
i have had a read through the thread on there 7 pages.
van is 4 years old but covered 105k so i want to get both belts done.
ford etis shows 150k or 10 years but i wont leave it that long.
Old Feb 6, 2015 | 10:38 PM
Carlos-Titx
ford etis shows 150k or 10 yers but i wont leave it that long.
no point doing it all twice.
Like replacing a
Dmf but not the clutch plates imo.
Old Feb 7, 2015 | 12:16 AM
botters's Avatar
botters
competant bodger
they usually snap well before they are due usually before 100k so you are on borrowed time! they are pretty easy to change slightly easier than changing the chains that preceded them i would estimate around £400 for an independant garage to change both belts and all tensioners etc
Old Feb 7, 2015 | 10:01 AM
220tel's Avatar
220tel
just got another price £984-92p its a belt for christ sake great move ford
Old Feb 7, 2015 | 10:25 AM
RichieST's Avatar
RichieST
The interval is 10 years or 125000 miles. Auto data say it's 8 hours to do both belts. I have been quoted about 800 from my local garage to do them on my mondeo. Not really a difficult job just very time consuming as the lower belt is buried!
Old Feb 7, 2015 | 10:37 AM
Carlos-Titx
A good reason to go with bigger engine.
Old Feb 7, 2015 | 11:01 AM
RichieST's Avatar
RichieST
I'll stick with something ford under the bonnet, fuck anything french
Old Feb 7, 2015 | 11:03 AM
220tel's Avatar
220tel
is there any special tools required to do the job
Old Feb 7, 2015 | 11:07 AM
Carlos-Titx
I can't do French cars either.
But just sold my ford
Old Feb 16, 2015 | 07:28 PM
220tel's Avatar
220tel
had this done today by a local garage with all genuine ford parts etc
wet belt, timing belt kit and aux belt for 550-00
Old Feb 16, 2015 | 09:37 PM
RichieST's Avatar
RichieST
Good price that, how many hours labour did they charge for?
Old Feb 17, 2015 | 06:25 AM
220tel's Avatar
220tel
they quoted me 500 -550 with 3 hours labour, they said it took there tech nearer 5 hours to do. They said the next one they do will be a bit more money.
Old Feb 17, 2015 | 11:50 AM
gcfcos's Avatar
gcfcos
Don't wanna come accross as a moron lol but what the hell is a wet belt? Even being a mechanic I've never heard of one. Is it a balance belt? Just asked the other mechanic at work if he's ever heard of one and he just gave me a blank look lol
Old Feb 17, 2015 | 12:27 PM
RichieST's Avatar
RichieST
5 hours is good going, you got lucky with them quoting you for 3. As I said above, autodata says it should take 8!
Old Feb 17, 2015 | 12:52 PM
Carlos-Titx
One belt goes from crank to fuel pump then a seperate one from pump to cam gear. I think.
Old Feb 17, 2015 | 01:47 PM
Bailes1992's Avatar
Bailes1992
The wet belt is nothing more than a cambelt in a casette that runs in oil.
Ford replaced the old lower chain that used to come on the Lynx diesels with a belt to improve emmisions and fuel economy. I believe it was fitted on all 1.8TDCi's from 10/07 onwards. Ford say that the interval is 125k/10 years but I've heard of a fair few failing at just over 90k.
Older Chain...
Newer Belt (fitted 10/07 onwards)...
And then you obviously have the usual cambelt...
A huge chunk of the cost of getting it replaced is the amount of bolts, seals and gaskets that need replacing.
I paid £620 at a main dealer but that included a bit of discount and a tank of diesel as I was messed about a lot.
Old Feb 17, 2015 | 01:48 PM
gcfcos's Avatar
gcfcos
Thought that may have been the case. . I remember the older connects where I used to work only had a belt from cam but bottom end was chain driven if I remember correctly. Did loads of timing belts on them only took 30 mins for the top belt
Old Feb 17, 2015 | 01:51 PM
gcfcos's Avatar
gcfcos
Been a while since I worked on a connect and the stock of them they had were up to 2007 plate (van hire rental firm) so suppose that's why I never came accross it! Thanks for clearing that up lol!!
Old Feb 17, 2015 | 05:27 PM
DangerousBryan's Avatar
DangerousBryan
Just had to rebuild a galaxy that snapped the bottom belt at 88000 miles.
Old Feb 17, 2015 | 08:12 PM
220tel's Avatar
220tel
hence why i wanted mine done
293 plus vat for parts alone, labour was 165 plus vat
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
stevecfrst1
Sep 30, 2015 05:18 AM
