Good 2wd head gasket
Old Jan 18, 2015 | 04:54 PM
3doorcozmess's Avatar
3doorcozmess
Default Good 2wd head gasket
Going for some head work and will need a good head gasket and bolts after as it'd only a 205 block can any one recommend please.
Cheers si
Old Jan 18, 2015 | 07:01 PM
The Youth.'s Avatar
The Youth.
ybo 611 (group A) or a standard small turbo escort cosworths one will be fine with standard genuine ford bolts
get them and all your cosworths parts from matt lewis motorsport
http://mattlewismotorsportonline.com/
steve
Old Jan 18, 2015 | 07:25 PM
3doorcozmess
Was thinking along the lines or wrc gasket. And I very much dout I'll be able to source genuine ford head bolts
Old Jan 18, 2015 | 07:29 PM
Billy_RS's Avatar
Billy_RS
You need to get the block decked if you want to use a WRC head gasket.
The group a from Matt Lewis will be sweet mate
Old Jan 18, 2015 | 10:20 PM
The Youth.'s Avatar
The Youth.
These are the same thing, ring matt he has them
http://mattlewismotorsportonline.com...inz-1396-p.asp
as for the wrc gasket yes if the head and block have been skimmed prior to fitting it if not then no, use what I've suggested above
steve
Old Jan 19, 2015 | 12:38 AM
saph-mad's Avatar
saph-mad
you can still get the bolts from ford there Ł50
Old Jan 19, 2015 | 06:12 AM
3doorcozmess
Really I've tried, no one can find them do you know the fins number
Old Jan 19, 2015 | 08:02 AM
Billy_RS's Avatar
Billy_RS
Matt Lewis does the group a head gasket with bolts as a set for Ł65 delivered. Job jobbed.
Old Jan 19, 2015 | 10:47 AM
Jay,'s Avatar
Jay,
Sponsor
As Bill and Steve has said speak to Matt
Old Jan 19, 2015 | 03:34 PM
R4N SS's Avatar
R4N SS
if you are getting head work done, you may as well skim the head and then use a wrc gasket
Old Jan 19, 2015 | 07:01 PM
The Crocodile Hunter's Avatar
Used a small turbo escos one on mine.
Old Jan 19, 2015 | 08:52 PM
3doorcozmess
That's what I was thinking.
Old Jan 19, 2015 | 08:58 PM
James @ M Developments.'s Avatar
So thats one flat surface, what about the block? that usually ends up around 4thou shallow around the centre head bolts. Unless you skim both surfaces flat i wouldn't use a metal style gasket,
Old Jan 19, 2015 | 11:24 PM
Billy_RS's Avatar
Billy_RS
Like I said, you'll need to get the block decked.
Old Jan 20, 2015 | 07:19 AM
cossynut2's Avatar
cossynut2
10 Year Member
I agree with you, I had a new 200 block, wire rung with a group A specification cylinder head with a group A head gasket fitted 15 years ago, run T38 with 2 bar boost and have never had a head gasket failure.
markk
Dec 2, 2021 06:59 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
turbotrev
Aug 22, 2015 11:41 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
