Clutch choice for 300bhp zetec turbo
Old Jan 18, 2015 | 01:25 PM
TomPengelly's Avatar
TomPengelly
Kapow!!
Default Clutch choice for 300bhp zetec turbo
Whats the best clutch to use for a 300 bhp zetec turbo using an rs turbo gear box (straight cut gears)?
On ebay theres an ap racing 4 paddle clutch kit for 220mm flywheel.
Its reduced to £337.
Would anyone advise me any different? If not, is there anywhere else cheaper??
Old Jan 18, 2015 | 03:03 PM
grant_xr's Avatar
grant_xr
My rst ap paddle was slipping under heavy load with less power than that. It had plenty life left in it too.
Never found out if it was the shitty xr2 clutch ratchet shitting itself or the clutch couldn't handle it as my gearbox let go stripping the teeth off 5th gear!
Putting a mk1 FRS setup in now.
Grant
Old Jan 18, 2015 | 03:28 PM
Churtz's Avatar
Churtz
I had to go to focus rs mk1 clutch and gbox.... couldn't find a clutch to do the job. That's at similar power to what you're running.
Old Jan 18, 2015 | 03:55 PM
crazycage's Avatar
crazycage
Helix do a extra heavy duty cover that will do 300ftlbs easy
Old Jan 18, 2015 | 04:44 PM
nevsrevs's Avatar
nevsrevs
dont bother with anything apart from helix mate, been there done that. or stick to mtx set up.
TomPengelly
Kapow!!
Is this the one you mean? Better than the AP Racing one?
http://www.burtonpower.com/helix-pad...o-90-4757.html
Old Jan 18, 2015 | 05:18 PM
TomPengelly
Kapow!!
Any comments or advise before i order this Helix clutch kit?
Cheapest i can find is 430 inc vat from burton power..
Old Jan 18, 2015 | 06:29 PM
nevsrevs's Avatar
nevsrevs
I ran a 6 paddle direct from them mate.
Old Jan 18, 2015 | 06:31 PM
nevsrevs's Avatar
nevsrevs
and make sure your flywheel is 100% spot on.
tell them your needs, think it was fred I used to deal with. but this was 10yrs ago and he was a old chap then.
Old Jan 18, 2015 | 06:41 PM
TomPengelly
Kapow!!
I could get my flywheel skimmed. Would it be ok to keep the standard one?
Old Jan 18, 2015 | 07:18 PM
crazycage's Avatar
crazycage
Yes the standard flywheel is fine mate
robnock
21
May 13, 2019 05:29 PM
neil18
Mar 14, 2016 01:08 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
