Next question - removing decals advice
Old Jan 17, 2015 | 10:28 PM
AndyPen's Avatar
AndyPen
Default Next question - removing decals advice
Ok, so next up will be finding an rs500 1/18 bumper and from what I see they will need repainting, but having the decals removed first. Nail varnish remover without acetone has been recommended and someone also said brake fluid is ok if it is going to be repainted. Any thoughts folks?
Old Jan 18, 2015 | 01:12 PM
Caddyshack's Avatar
Caddyshack
Won't brake fluid melt the plastic in the model? There is stuff call "sticky stuff remover"
Old Jan 18, 2015 | 01:27 PM
Chopshop85's Avatar
Chopshop85
Even acetone free nail varnish remover can damage the plastic as I once discovered.
You could try dettol (make sure its got Chloroxylenol in it). Its what I use to remove paint/varnish from models. Mix it about 50/50 with warm water. Submerge the part, leave it for 12-24 hours. The only down side to this is Dettol has a very strong smell.
Old Jan 18, 2015 | 01:28 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
A little petrol on a cloth is good at breaking down sticky residue from stickers
Old Jan 18, 2015 | 03:17 PM
thebigmacmoomin's Avatar
thebigmacmoomin
If its metal, use paint stripper back to bare metal, then prime, paint, laquer & polish. Metal parts only.
If its plastic or resin, paint stripper will melt it.
I have used brake fluid & acetone free nail polish remover before.
All I would do is sand it down so the decals are gone, then paint as above.
Old Jan 18, 2015 | 07:29 PM
roomey's Avatar
roomey
Oven clean is great use it all the time on plastic models
Roomey
Old Jan 18, 2015 | 09:30 PM
AndyPen's Avatar
AndyPen
thanks for the ideas guys, this is never straight forward but does look like fun
Old Feb 1, 2015 | 08:05 PM
AndyPen's Avatar
AndyPen
They were printed logos etc - so used brake cleaner and they came off brilliantly
Aug 29, 2015 08:16 PM
cos4ever
Ford Escort RS Cosworth
Aug 26, 2015 10:05 PM
Bosch
Aug 4, 2015 05:14 PM
no1trancefan
Aug 4, 2015 12:48 PM
