Baileys dump valve - which one?
Old Jan 16, 2015 | 06:41 PM
Churtz's Avatar
Churtz
Default Baileys dump valve - which one?
Evening all.
just a quick one i hope - i know baileys do dump valves for cars with air flow meters, and those without. I understand why cars with an airflow meter must have that one, so the dump valve seals when its not dumping even under vacuum conditions.
BUT....
would i be able to use a dump valve designed for an airflow meter car on a car without? im guessing it would mean its just a sealed system under vacuum, whereas the other would be free flowing until boost conditions...right?
Its just ill be buying a used one and have been offered one from an airflow meter car
Thanks very much.
Matt
Old Jan 17, 2015 | 09:27 AM
costina's Avatar
costina
Live long and prosper!!
What car? Twin piston is for airflow metered cars single for cosies etc. the only real world difference with a twin piston on a cossie is the lack of whistle on idle. With a single it remains open at idle.
I think they are ok but would be better with some kind of filter imo
I use a single piston on my cossie.
Old Jan 17, 2015 | 02:43 PM
Churtz's Avatar
Churtz
My car doesnt use an airflow meter, but i was just checking it would be ok to use a dump valve designed for one. Just means all of the air will come through the turbo when idling etc i guess.
Thanks for the reply.
Old Jan 18, 2015 | 01:09 AM
Oranoco's Avatar
Oranoco
Fitted my old RST one on my Audi for a laugh. Didn't work, made the ftsh sound but was followed up by a weird droning buzz sound like old plumbing. Relocated the Bailey Dv to the spares box where it still sits 6 years later.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
