2.5 Transit injector question
A strange one, but I am working on a boat that has a marinised 2.5 banana engine fitted. without banana manifold. it uses a marine inlet and exhaust manifold with turbo.
I have a problem with the injectors. I need to test them for a starting problem and can not find what the opening pressures should be?
Also when looking at replacing the injectors its identifying the ones that should be in it?
There are no colour dots on these as they have all been painted. looking at it though it should have 100ps blue dot ones on as its a turbo engine?
Is this correct?
Thanks
Is this correct?
Thanks
DixieTheKid
11
Jun 6, 2020 11:20 AM
