polys and coilovers
Old Apr 1, 2005 | 08:35 AM
moonstone mike's Avatar
moonstone mike
Default polys and coilovers
Im about to fit coilovers on my 3dr and poly bushes, is it worth changing the rubber in the front top mount with the poly type????
Anyone got coilovers on there 3 dr????
Old Apr 1, 2005 | 03:04 PM
Niall.b's Avatar
Niall.b
Yes as the standard ones might as well be made from marshmallows. i put a set of leda's in mine 2 years ago dumped the anti-roll bar at the front & fitted compression struts. also put eccentric top mounts in for bags of adjustment. It handles like a dream on good roads but is a bit noisy and hard on the B roads even with the shocks set at there softest.
Old Apr 3, 2005 | 10:18 PM
kennyA's Avatar
kennyA
Hi
Also fitted Leda coilovers just today, used TAS top mounts. The car is now sitting about 2" higher with the adjustment ring right at the bottom.. Will need to decide if the spring length needs to be shorter.
will test the car when its fully rebuilt, in 4 weeks.
Kenny
Old Apr 4, 2005 | 03:37 PM
moonstone mike
what is TAS ??? who do them ???? why is your car sitting so high???
did you fit them on a 3 door???
no more questions
Old Apr 4, 2005 | 04:12 PM
Niall.b's Avatar
Niall.b
TAS - tel 01772 454647, make the top mounts
or www.tas.uk.com
Old Apr 5, 2005 | 04:20 PM
kennyA's Avatar
kennyA
apologies, it's not a 3dr. Escort 4x4 but the principle is the same.
TAS make eccentric top mounts, this means you are able to adjust camber and castor. I am still experimenting so I cannot get into any more detail. Cost is usually around Ł100 per item for escort.
Fitting top mounts with rose joints removes any rubber from the suspension, probably too hard for a road car. It's all up to the individual.
kenny.
Old Apr 5, 2005 | 04:32 PM
moonstone mike
Thanks ...but i dont want to go down that road, i just wanted to know about changing the standard rubber with the poly type?????
mk1turboestate
Dec 2, 2015 08:31 PM
gcfcos
59
Oct 6, 2015 05:04 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
pabloXR
Sep 21, 2015 12:42 PM
