Limits of a T34?
Old Jan 2, 2015 | 04:11 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Default Limits of a T34?
What sort of numbers can a standard Cosworth T34 push out? I'm gathering parts for a 940 turbo, and as it's a T3 flange it should fit with a bit of jiggery pokey, I'm hoping for 350bhp but closer to 400 would be nice! Will it run out of puff before then?
Also, if anyone has one laying around they wish to get rid of, let me know
Ben.
Old Jan 2, 2015 | 04:14 PM
Staffi's Avatar
Staffi
On it's limits @ 400 Ben, good spec'd engines will do it but as said, turbo life is very limited.
With a .63 housing and good spec and 2 bar, 2.2 bar peak will be a nice 370-390 car with similar torque.
If you want 400 get a bigger turbo and run less boost and this will also help turbo life too
Old Jan 2, 2015 | 04:26 PM
Ridgey's Avatar
Ridgey
As Pete say upto 400bhp for reliable power.
I've just had mine mapped and just over 2 bar holding as much as it can up the revs gave 410bhp
If your wanting to run good power you should definitely have a 360 degree bearing in it.
Old Jan 2, 2015 | 04:38 PM
James @ M Developments.'s Avatar
Boost control is critical to get good numbers from a T34, you need to get them to hang onto boost at high rpm, my esc cos did 414bhp peaking at 28psi, but holding 26/27 using an aftermarket controller.
A spike in boost wont gain you bhp but give a spike in torque.
Old Jan 2, 2015 | 04:40 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Cheers for the replies chaps, unfortunately the standard 8v head on a 940 isn't particularly free flowing so without plenty of head work it needs plenty of boost down its neck, so perhaps a bigger turbo might be a wise choice.
It's a proper budget build as they're wildly over engineered as standard, I looked into a HX35 but that seems more like a 500bhp turbo which is a bit overkill is it not?
Another option was a cheap Chinacharger but that's probably asking for trouble lol.
Old Jan 2, 2015 | 04:42 PM
scoooby slayer's Avatar
scoooby slayer
Are they 2.0 or 2.5?
Old Jan 2, 2015 | 04:45 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
It'll be on a MBC for the time being.
Was that on a standard T34?
I'm not dead set on 400, however I can imagine it'll soon end up getting that way!
2.3 4 pot mate.
Old Jan 2, 2015 | 04:46 PM
Yeah mine was a factory T34.63 on a std engine with 72lb injectors
Old Jan 2, 2015 | 05:06 PM
costina's Avatar
costina
Live long and prosper!!
James, could you post up your dyno graph for you T34/48 on 55lbs that was on your saff.
Paul
Old Jan 2, 2015 | 05:20 PM
If I have it I will have a look later
Old Jan 2, 2015 | 05:23 PM
costina's Avatar
costina
Thanks
Old Jan 2, 2015 | 05:29 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Have any of you had experience with Holsets? They're very popular with the Volvo boys over in Sweden and the likes, seem to be well priced too.
Old Jan 2, 2015 | 05:40 PM
scoooby slayer
Make sure ur exhaust is big enough, I had a gt40 on 0.85 ar and changed upto 1.05 ar on a 2.65 litre and picked up over 100 hp from that alone!
And I backed up the extra dyno power by 30-130 being over 1 second quicker
Old Jan 2, 2015 | 06:20 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Do you mean make sure the exhaust housing is big enough or the exhaust itself?
Old Jan 2, 2015 | 06:31 PM
scoooby slayer
Turbine housing bud, although I seem to remember my old t4 was on a t3 0.63 housing and that did 472 hp
Cosnada
Jan 7, 2016 05:30 PM
Russ Payne
Sep 25, 2015 08:29 PM
