ST24 Traction Control and battery light problem...
Old Jan 1, 2015 | 07:18 PM
nickscunny's Avatar
nickscunny
Unhappy ST24 Traction Control and battery light problem...
After an enthusiatic drive in the ST24 yesterday I noticed that when my Traction Control is off, I'm getting Handbrake Warning light, Traction Contol and ABS lights on at the same time. Once TC is switch on, no lights. Not only that, I'm getting an intermittent battery light on which manages to come off after about 2500 revs. Once the revs drop it comes on again This happens regardless of TC on or off...
This all happened during the same drive so I'm presuming its all related though I'm confused. Battery light on at low revs and when TC is off I get warning lights appear! ABS/TC/Charging fault
The car has had a new battery, new alternator and new belt fitted a few months ago...
Old Jan 1, 2015 | 07:32 PM
RichieST's Avatar
RichieST
Have you done any checks to make sure its charging properly? Low voltage will cause all sorts of weird ecu / module faults.
Old Jan 1, 2015 | 07:36 PM
nickscunny's Avatar
nickscunny
I'm going to have an afternoon on it tomorrow, My mate has said to check all my earth straps and to check my wheel sensors...
Kam B
Sep 24, 2015 10:40 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
markk
Sep 9, 2015 08:11 AM
cameron2
Sep 6, 2015 10:40 AM
fuzzy
Sep 4, 2015 10:11 PM
