Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
MK5 1.25 how to change lifters/tappets
Old Dec 4, 2014 | 02:36 PM
grishenko45's Avatar
grishenko45
Default MK5 1.25 how to change lifters/tappets
hi all,
my 1.25 mk5 has been sat in the garage for almost a year now, and i need the space. i've not made any time for it at all. too many holidays means i've not put the time or money aside to fix her.
i've borrowed an automotive stethoscope and the locking bar and pins for the cams,. i'll replace the lifters. I've got a whole new set of 16 to put in.
the engine mount doesn't need to come off because I'm not changing the belt ... is that right? it's only done 20K since it was done.
how do I remove the cams without messing any timing up? are they ok to take out with the setting bar in place?
how are the lifters fitted? just pushed on?
thanks
Old Dec 4, 2014 | 05:49 PM
16imarty's Avatar
16imarty
They are shimed so u just cart change them
Old Dec 4, 2014 | 07:42 PM
grishenko45
what do you mean 'cart change them'? they just pull out? suction cup them out?
can i just take the cams out after the belt is removed, after i've loosened the cam pulleys?
Old Dec 4, 2014 | 09:08 PM
16imarty's Avatar
16imarty
U have to measure the gap then see wot size is fitted caucalte to spec
Wots reason y u changing them
Old Jan 18, 2015 | 12:08 PM
grishenko45
the lifters on the exhaust cam cylinder #4 aren't opening enough so they're tapping on the cam lobes and making a racket!
Old Jan 18, 2015 | 12:34 PM
RichieST's Avatar
RichieST
They all make a racket, it's just how they are lol. As said though, they are shimmed, you shouldn't have to replace the lifters themselves, just adjust the thickness of shims.
Old Jan 18, 2015 | 12:44 PM
grishenko45
these are so bad it's like there's bits getting flicked around in there.
Old Jan 18, 2015 | 12:48 PM
RichieST's Avatar
RichieST
How many miles has it done? Got the correct grade of oil in it?
Old Jan 18, 2015 | 12:51 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
The little SE shouldn't tap, they should be nice and smooth.
Old Jan 18, 2015 | 05:21 PM
grishenko45
yeah had the correct grade of oil in it. done 70k but i ragged it to death!
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
