xr3i efi running problems
Old Dec 2, 2014 | 09:45 PM
mk3matt's Avatar
mk3matt
Default xr3i efi running problems
Hi,
I have an xr3i thats been off the road for some time.
Its an efi lump
Basically, it idles rough and feels a bit nder powered. If i unplug the temp sender on the RHS of the 'EFI' wording on the inlet, once the car is warm, it idles much better and stops trying to stall.
So i have done;
New idle control vavle (well - replaced with a known good one)
Replaced that sender (think its called the charge/air temperature sender)
Oil and filter change
I cant help but wonder if the mixture screw thing that sits near the battery is faulty... and when the temp sender is plugged in, it reads from this and get a shit reading... so when it is unplugged, the car just goes onto a base map.
Help
Im in Colchester if there's any locals who have some knowledge. Its running and driving but i want it to be pukka as its the gf's daily.
Old Dec 3, 2014 | 08:55 AM
mk3matt's Avatar
mk3matt
Bumpppp
Old Dec 8, 2014 | 04:02 PM
mk3matt's Avatar
mk3matt
anyone?
Old Dec 8, 2014 | 04:36 PM
Cardie's Avatar
Cardie
Not 100% on these but try a new engine temperature sensor. Might be telling the ECU its running cold, when the inlet is hot, when you unplug the inlet temp sensor they will both have a corresponding value and make the engine run as if its cold, will idle higher and a lot better.
Old Dec 8, 2014 | 05:16 PM
mk3matt's Avatar
mk3matt
thanks for reply. I should have updated, I changed the temperature sensor on the weekend and the problem is the same?
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 17, 2015 12:21 PM
marky_g
Aug 15, 2015 10:43 AM
stevierob
Aug 11, 2015 09:08 PM
