MK4 Escort clutch pedal problem
Old Dec 2, 2014 | 08:50 AM
anthony lea's Avatar
anthony lea
Ford allegiance
Default MK4 Escort clutch pedal problem
So it begins...
Came home from my first proper drive out in my MK4 1.3 last night and when reversing up the drive it sounded like something snapped? and the clutch pedal went straight to the floor and subsequently stalled.
Not looked at it yet and with the dark nights it will prob be the weekend but has anyone any initial thoughts on what might be the problem?
Old Dec 2, 2014 | 09:14 AM
haz87's Avatar
haz87
Either cable has snapped or ratchet has gone bang
Old Dec 2, 2014 | 03:01 PM
S2 Cabby's Avatar
S2 Cabby
Ratchet gets my vote, quite common but only a few quid to replace
Old Dec 2, 2014 | 04:09 PM
anthony lea
Ford allegiance
Yeah someone else suggested this but i've heard it's a ballache to replace?
Old Dec 2, 2014 | 05:52 PM
haz87's Avatar
haz87
Yup, fiver in parts, lifetime of patience
Old Dec 2, 2014 | 08:13 PM
danrst77's Avatar
danrst77
danman
Defo the ratchet gone mate, I used to do them when I worked at ford back in the 90s
Not a very nice job at all,,, I had to do my gf's rst s2 Last year, but I lost my rag with it
and got someone else to finish the job off for me lol
I had more patience back then
Old Dec 5, 2014 | 12:23 PM
anthony lea
Ford allegiance
I don't know if this helps but as i was trying to have a little nosey round the pedals this lunch time this little metal clip fell down. Can anyone confirm if this may well be the cause of the problem?
Old Dec 6, 2014 | 06:25 PM
xrmalin's Avatar
xrmalin
That clip looks like the one which goes on the brake pedal, if it is that's nothing to do with your clutch problem.
Old Dec 6, 2014 | 06:44 PM
anthony lea
Ford allegiance
I think I'm going to take the dash out and fix it properly for peace of mind as everywhere I've looked it seems to be a nightmare of a job even with the drivers seat out!
I'm one of them who can't sleep at night worrying about stupid things
Old Dec 6, 2014 | 07:25 PM
3i Jim's Avatar
3i Jim
10 Year Member
It'll take longer but a lot easier with the dash out.
Old Dec 6, 2014 | 08:10 PM
danrst77's Avatar
danrst77
danman
Yeah that clip goes on your brake pedal rod,,,
If you wanted you could take the whole pedal box out
Instead of dash ?
Old Dec 6, 2014 | 10:44 PM
botters's Avatar
botters
competant bodger
is it just me that does not find clutch ratchets difficult to change then lol! after you have changed a clutch cable on a citroen xantia all others feel easy lol
Old Dec 6, 2014 | 11:00 PM
studabear's Avatar
studabear
when putting it all back together glue the bushes into the pedals
Old Dec 8, 2014 | 08:14 AM
anthony lea
Ford allegiance
Ok so ive now removed the dash (no fun with a hangover) but it still looks like its going to be a ballache!
It does seem that the clip is from the brake pedal rod.
From what i can see/feel it seems as though the spring on the pawl isnt under tension and therefore not pressing against the ratchet?
So next job is to remove the pedal and investigate....
Can anyone tell me how to remove the speedo cable from the back of the clocks?
Old Dec 8, 2014 | 11:01 AM
studabear's Avatar
studabear
Squeeze the sides of the cable connection at the back of the speedo head to release it.
Old Dec 8, 2014 | 01:28 PM
stevo123's Avatar
stevo123
Put tie wrap on the big spring so you can pull it down onto the pedal last so you can assemble the gummins while it's not under tension
Old Dec 8, 2014 | 01:42 PM
anthony lea
Ford allegiance
Sorry mate i dont quite understand what you mean?
Old Dec 8, 2014 | 03:01 PM
stevo123's Avatar
stevo123
big spring that connects onto the quadrant and the pedal. Put it on last but it's too strong to do using fingers so tie wrap the end and then yuk the tie wrap with a pair of plyers or similar to hook it onto the pedal. Will make sense when you look at at hopefully bud.
Old Dec 8, 2014 | 03:34 PM
anthony lea
Ford allegiance
Ok mate cheers for the heads up
Old Dec 21, 2014 | 05:35 PM
danrst77's Avatar
danrst77
danman
How did you get on mate ?
Job all done yet ?
Old Dec 21, 2014 | 06:46 PM
anthony lea
Ford allegiance
Job all done yet ?
Not touched it since mate with the dark nights (and working all week) and usually too busy or hungover at weekends!
Plus it really peed me off ( first hour after taxing the thing) so gonna wait till after christmas.
I need to build a garage!
Old Dec 22, 2014 | 01:45 PM
anthony lea
Ford allegiance
Off work today so couldn't resist removing the pedal out for a nosey!
It seems its been replaced before with aftermarket parts.
Does anybody know which colour I need to order or how I measure this current quadrant?
I know people say replace with same colour but with it being aftermarket I suppose they could make them any colour?
Old Dec 22, 2014 | 10:04 PM
tony66's Avatar
tony66
Default rachet
i hate them too...easier with a sunroof and seat out
as far as colors it just all needs to match-the ratchet and pawl that is...get the same size though
Old Dec 23, 2014 | 11:05 AM
anthony lea
Ford allegiance
Sunroof ???
Old Dec 24, 2014 | 08:44 PM
tony66's Avatar
tony66
Default sunroof
on back feet out of sunroof head under dash....
Old Dec 24, 2014 | 10:40 PM
Chas's Avatar
Chas
Ah, the good old Escort Quadrants! How I hope the plastic one in my car lasts with a Helix 4 paddle clutch...
Anyway,
Add a Pug 306 GTi-6 with AC to that list (that almost require telepathy) with the 106 coming a close second (Steering rack and other pipes are in the way. The 306 DTurbos (non AC) were where you could not see what you were doing but they were relatively simple IME (less crap for the cable to get trapped in!). When I saw the Quadrant in my RST it did not look great on the back but it did look doable in comparison to the above clutch cable changes.
I knew I forgot one! BMW E36 pollen filter changes ; did they design a car around a pollen filter?
Old Jan 4, 2015 | 10:14 AM
anthony lea
Ford allegiance
Finally sorted this yesterday
Got a rebuild kit, genuine Ford for 4 quid delivered. Quadrant, pawl, bushes and spring
Not too bad really but access makes you curse!
I removed seat which enables you to lie on your back with feet on rear bench
Remove cable gearbox end
Disassemble pedals and replace new parts
Leave the spring attached to the quadrant off at the clutch arm end and securely attach some metal wire to it through the small hole (copper?) leaving enough to grasp
When reassembling put clip on brake pedal side first then at clutch pedal side push clip over widest point at very end and work it along until it falls in its recess
Push pawl up with finger and move quadrant round to enable more cable at gearbox end and then attach cable at gearbox
Finally pull the wire through the hole to hook spring on the arm which will tension the quadrant
Hopefully this will have fixed it
Old Jan 4, 2015 | 03:58 PM
anthony lea
Ford allegiance
So I've been for a drive for a couple of hours and still ok so pretty happy
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
