Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Help needed with a rough running Focus
Old Dec 1, 2014 | 06:21 PM
oooMURPHooo's Avatar
oooMURPHooo
Default Help needed with a rough running Focus
Hi all, I have bought my better half a 2000 1.8 petrol focus as her first car and I am having a few issues. The car runs great when cold but when it starts getting up to temp' the problems start. It will idle around 600 rpm and miss as it is stood. Also when driving anywhere between 1 - 2000 rpm it is down on power, coughs and judders. As soon as you get above 2000 rpm it starts to behave itself. I have changed the HT leads (after getting a shock off one) and plugs. I also found a split PCV hose which I replaced. I have had a look at the MAF sensor and it looks very clean. Any ideas would be great, unsure if there are any methods for testing the MAF with a voltmeter just to make sure?
Many thanks.
Old Dec 1, 2014 | 07:41 PM
studabear's Avatar
studabear
have you had it scanned for any fault codes?
Old Dec 1, 2014 | 07:46 PM
oooMURPHooo
I scanned it and got P0113 & P0171. I checked again today and nothing has come back.
Old Dec 1, 2014 | 08:04 PM
RichieST's Avatar
RichieST
Unplug the MAF and take it for a drive. Engine light will come on so you will need to reset it after.
Have you changed the coil pack? Pretty common failure on the zetecs.
Old Dec 1, 2014 | 10:12 PM
JamesH's Avatar
JamesH
What do the codes mean?
Old Dec 2, 2014 | 10:55 AM
oooMURPHooo
Just took it out without the MAF connected and it was just as bad, I noticed today that the scanner has the Oxygen sens & Oxygen htr showing as INC instead of ok.
Old Dec 2, 2014 | 10:57 AM
oooMURPHooo
Sorry mate
P0113 - Intake Air Temperature sensor 1 Circuit High
P0171 - System too lean Bank 1
Old Dec 2, 2014 | 01:06 PM
oooMURPHooo
Well I took it for a spin this afternoon to see if I could get any error codes to show and the speedo cut out until I switched it off and back on. Could this be linked to the rough running/idle? Possibly Vehicle Speed Sensor?
Old Dec 2, 2014 | 01:08 PM
studabear's Avatar
studabear
They do lose a bit of oomph when the vss messes about. Well mine did.
Old Dec 2, 2014 | 01:26 PM
oooMURPHooo
The strange thing is that it seemed to run much better when the speedo was out.............give in!
Old Dec 2, 2014 | 07:48 PM
RichieST's Avatar
RichieST
You really want to be reading the live data from various sensors to see what is going on. Sometimes handing it over to a specialist to diagnose will work out much cheaper than chucking parts at it hoping it will solve the problem.
Old Dec 2, 2014 | 09:41 PM
JamesH's Avatar
JamesH
Bank too lean is probably the hose under the inlet manifold that goes to the breather/inlet manifold
About £20 from Ford
Old Dec 2, 2014 | 09:43 PM
JamesH's Avatar
JamesH
They perish/split. Took me a while to find it!
RSmark84
Concours d'élégance.
50
Aug 30, 2015 05:03 PM
saph in dorset
Aug 14, 2015 10:10 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
col93saphcos
Aug 7, 2015 03:21 PM
salsheikh
Jul 30, 2015 08:45 PM
