Battery problem
Old Nov 25, 2014 | 05:14 AM
Fordmad!'s Avatar
Fordmad!
Default Battery problem
Right I bought a new battery for my rs2000 when I bought it around 4 months ago and its been fine since. I didn't touch the car for 2 weeks came to it and it as flat.
Ive jumped the car a few times now took the car out quickly to charge it up. Come to it the next day, flat again!
Now there is a alarm/immobiliser on the car and im thinking the standard battery might not be big enough to cope with the alarm.
Either that or I have a drain.
Ive took the battery off and have put it on charge to see if that helps.
Think I may get a big diesel battery on it
Any ideas
Old Nov 26, 2014 | 12:34 PM
martysmartie's Avatar
martysmartie
Any ideas
It's quite possible for the alarm to drain it after that time.
Taking it out 'quickly' won't be long enough to charge it.
Martin
Old Nov 26, 2014 | 01:14 PM
adam151082's Avatar
adam151082
Put a volameter over the battery and pull and replace one fuse at a time till you find the drain.
Old Nov 27, 2014 | 10:39 AM
roger69's Avatar
roger69
Any ideas
Have you checked that it isn't draining back through the alternator if the diode is faulty happened to me once
Old Nov 27, 2014 | 05:40 PM
Fordmad!'s Avatar
Fordmad!
I havnt had chance to check anything yet.
How do I check if its draining back through the alternator?
jay030787
Sep 18, 2015 04:38 PM
Flatlinedan
Sep 18, 2015 12:41 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
cameron2
Sep 6, 2015 10:40 AM
