RS turbo sump gasket issue
Old Nov 21, 2014 | 08:47 PM
rs_jim's Avatar
rs_jim
Default RS turbo sump gasket issue
Hi all on my 3rd sump gasket now....tried several ways I.e gasket to the sump / gasket to the block / with and without silicon sealer on the half moons it's fine ticking over no leaks take it up the road come on boost it blows the gasket out which means crankcase compression got a breather setup on it . Could the breather be causing this getting fed up now with it
Many thanks
Old Nov 22, 2014 | 02:01 AM
cossiestu's Avatar
cossiestu
It took me about 3 goes to it right, don't think it was a breather problem, just me being a tit!
Am I right in thinking the most reliable way is to stick it to the block not the sump, not helped by gravity...
Old Nov 22, 2014 | 05:33 AM
danrst77's Avatar
danrst77
danman
Default Rs sump gasket
Same thing with my s1
Had my gasket put on with the engine out, ( when engine was rebuilt )
But still bloody leaked,
Just try n error I think ;(
Old Nov 22, 2014 | 07:32 AM
anthony lea's Avatar
anthony lea
Ford allegiance
Its soul destroying isn't it!
As said people fit them with the engine on the bench and they still leak
Old Nov 22, 2014 | 08:59 AM
Piston Broke's Avatar
Piston Broke
Just done mine first time no leaks, The only thing i will use is a Granville high temp sealant, stick the gasket to the sump, leave 10 mins then seal it to the block with the sump, sorted, first time every time so far ................... http://www.hids-direct.co.uk/granvil...FUzHtAodFU8ACg hope that helps
Old Nov 22, 2014 | 06:03 PM
rs_jim's Avatar
rs_jim
Yeah but it's fine if I drive it when it's not on boost for about 25 mile ......soon as I come on boost the gasket leaks has anyone got a standard breather forsale ??
Old Nov 23, 2014 | 02:41 PM
rs_jim's Avatar
rs_jim
Any help much appreciated
Old Nov 23, 2014 | 06:46 PM
Piston Broke
If you are running boost and its blowing your gasket before your dip stick or oil fill cap i think you have blow by ring issue and also should upgrade to a baileys oil separator system but that info i have told you try it first before saying it wont work
Piston Broke
Do a leek down test to
Old Nov 25, 2014 | 08:29 AM
rs_jim's Avatar
rs_jim
Thanks mate yeah just soon as I come on boost it does the gasket! will try thanks mate a victor reins gasket ok
3i Jim
Nov 20, 2015 05:12 AM
James Porter
Oct 28, 2015 12:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mrknifey
Aug 30, 2015 11:48 AM
Anutternutter
Aug 21, 2015 06:07 PM
