base setting distributor
Old Nov 9, 2014 | 04:16 PM
mgtkr1's Avatar
mgtkr1
Default base setting distributor
having ust fitted a rebuilt engine to my escort (cvh turbo on mfi) I want to set the dizzy so that its safe enough to get me started and then its going for a setup. im not going to go out giving it boot full's or anything I just want to where to set the dizzy. is there a mark on the cyl head that the dizzy lines up with or anything? im struggling, the last thing I want is a melted engine. also what do you recommend in terms of ignition timing? the last tuner did it at the standard 12 degree's last time even though it was running a bar of boost. I saw somewhere that 8 deg btdc is safer on modified engines.. thanks in advance, if you will pardon the pun
Old Nov 9, 2014 | 04:47 PM
martysmartie's Avatar
martysmartie
I think there may be a mark, and yes as a rule you retard with boost.
Remember this is only a base setting, the ECU controls the timing, as you will only be driving it gently, it's not so much of a concern, as you will be getting it setup.
Martin
Old Nov 9, 2014 | 04:56 PM
mgtkr1's Avatar
mgtkr1
thanks mate. im struggling to locate the mark on the head that's all, assuing there will be one
Old Nov 9, 2014 | 05:06 PM
martysmartie
There is defiantly a dot on the head, which the cam pulley should align with, this is for engine timing though, if your dizzy has been removed, then this won't work.
Your better off using a strobe light really.
Martin
Old Nov 14, 2014 | 10:05 AM
roger69's Avatar
roger69
Default Base setting distributor
After setting cam to tdc put dizzy drive slot into end of cam it only goes in one way turn it until marks line up the one on the head may be faint as it is done at the factory when it is timed it is about 12oclock if you need to set it to 8degrees turn engine back 2lines from tdc mark on the cam cover and reset dizzy
Old Nov 14, 2014 | 10:34 AM
haz87's Avatar
haz87
Using the dot is not a good way to set base timing. Use a proper timing gun and plug the vac line
Old Nov 14, 2014 | 05:56 PM
mgtkr1's Avatar
mgtkr1
I have found the mark on thehead,is thedizzy mark a cut out in the casting?
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
dms04
Sep 11, 2015 01:57 PM
3doorcozmess
Sep 7, 2015 01:32 PM
turbowag
Sep 3, 2015 08:07 AM
