No oil pressure on xr2
Old Nov 6, 2014 | 11:48 AM
roger69's Avatar
roger69
Default No oil pressure on xr2
Just changed my engine as I could not resolve the smoking so have put in another s/h lump but know have no oil pressure indicated so put in a gauge but still nothing oil filter is dry as a bone and no sign of any oil ln the head(rockers) I do have oil in the sump.I have not started yet but just turned it over with no plugs in(old engine used to show pressure just turning it over loath to start it with no oil pressure)
Old Nov 6, 2014 | 11:59 AM
haz87's Avatar
haz87
Did you prime the oil pump before chucking it in?
If its been sitting dry for a while it will take a fair while to self-prime through cranking (which isn't good for the bearings etc)
Old Nov 6, 2014 | 12:13 PM
roger69's Avatar
roger69
Engine came with oil in it so assumed it was OK was told it was quite running but did change oil and filter oil in it was well over top mark on dipstick and no sign of oil in head so was suspicious.
Old Nov 6, 2014 | 01:41 PM
haz87's Avatar
haz87
Coming with oil in it means nothing. Could have sat for 20yrs with oil in the sump for all anyone knows.
Sounds like the pumps dry. Its hassle but i'd whip it off and prime it or if you wanna chance it, keep cranking with plugs etc out till you hopefully see pressure (will probably need a jump pack across the battery otherwise you'll kill off that - oh and try not to burn out the starter too)
Old Nov 6, 2014 | 09:59 PM
mgtkr1's Avatar
mgtkr1
I had this trouble just yesterday. I filled the oil pump via the pressure relief valve, turned it over with the plugs out and within 5 seconds it was pumping. I had a moment of panick thinking the worst. its fiddly but not too bad to pour some oil into the pump in situ
Old Nov 7, 2014 | 10:29 AM
roger69's Avatar
roger69
I'll try that before I drop the sump . I was told that it hadn't been run for 8 months back in April when I bought it but it had no sign of any oil in the cam or rockers was dry as a bone should have had some sign of oil.
Old Nov 7, 2014 | 10:10 PM
studabear's Avatar
studabear
If you can't get oil pressure after priming the pump, the pick up could be blocked or something worse. Or you might just have to start it for a couple of seconds.
Old Nov 10, 2014 | 07:39 PM
mgtkr1's Avatar
mgtkr1
hopefully priming the pump should solve it
Old Nov 10, 2014 | 08:03 PM
slammedorion's Avatar
slammedorion
Or pull it round the block with the plugs out, just keep letting the clutch out with ignition on... Hopefully light will go out?
Old Nov 13, 2014 | 02:21 PM
roger69's Avatar
roger69
OK now took filter off and filled input gallery turned it over a couple of times replaced filter turned it over about 10 seconds and got 50 psi now got it started with 75 psi showing .
Thanks all you lads for your advice
Old Nov 13, 2014 | 04:22 PM
haz87's Avatar
haz87
Good news!
Old Nov 14, 2014 | 08:30 PM
mgtkr1's Avatar
mgtkr1
nice one mate
SMILER258
Sep 28, 2015 09:04 AM
