Mk4 Escort engine fan not working.
Old Nov 3, 2014 | 10:29 AM
rbkr's Avatar
rbkr
Default Mk4 Escort engine fan not working.
Hello, it's been a while since I have posted on here but I now own a MK4 XR3i. Anyway I took her out for a nice drive and noticed that the cooling fan isn't kicking in. I have tried bridging the connection (at least I think I have, I put a paper clip in the connection from the fan) and the fan didn't run? I have checked the fuse and also the fan spins freely by hand. If possible I want to fix it myself, any ideas?
Old Nov 3, 2014 | 10:47 AM
haz87's Avatar
haz87
Check if your getting power first. If you are then you know the fans faulty, if your not then its obviously a wiring issue.
Edit: The above is presuming you bridged it correctly
Old Nov 3, 2014 | 12:24 PM
rbkr's Avatar
rbkr
I am a massive newbie to this lol but really want to learn! So how do I check if I'm getting power? If the fan was faulty could I just replace the motor?
Old Nov 3, 2014 | 12:32 PM
haz87's Avatar
haz87
Use a multimeter.
And yes you could just replace the motor/fan unit
Old Nov 3, 2014 | 01:52 PM
rbkr's Avatar
rbkr
So do I just connect a multimeter to the connection that goes to the fan? Is there a relay for the fan?
Old Nov 3, 2014 | 06:53 PM
RichieST's Avatar
RichieST
Take the wiring plug off the fan switch in the radiator, insert paperclip or piece of wire into plug you have just removed, to bridge the 2 wires together. (don't forget to have ignition on)
If it doesn't work, put the black wire of your multimeter to a good earth, and one of the pins in the plug that you have removed should have power. (again check with ignition on)
Try this and see what you have.
Old Nov 11, 2014 | 07:31 PM
rbkr's Avatar
rbkr
Fixed thanks for the help
Old Nov 11, 2014 | 08:15 PM
RichieST's Avatar
RichieST
What was the fault then?
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
