Brake problem rs1600i
Old Oct 31, 2014 | 03:02 PM
pjv7771's Avatar
pjv7771
Default Brake problem rs1600i
Having a nightmare with my front brakes, everything bleeds through perfectly and the brakes are free but as soon as they warm up the fronts start binding badly, master cylinder is brand new so I don't think its that, I've got rs turbo calipers and discs on the front and and xr4i disc conversion on the rear with an adjustable bias valve, rear discs seem fine though it's just the fronts, would appreciate any help, thanks in advance
Old Oct 31, 2014 | 05:04 PM
2classics's Avatar
2classics
Have had that prob before and made sure pistons are moving freely plus new pads maybe over sized causing binding when hot..
Old Oct 31, 2014 | 07:22 PM
JPA's Avatar
JPA
Run the car till brakes are binding then take off wheels , if you can't push back Calipers as normal then open a bleed nipple and try it , if they then go back problem lies with flexi pipe
It will have an internal blister acting as a one way valve for the fluid
I'm assuming master cylinder is same type and there was clearance when you tightened it onto the servo ?
John
Old Oct 31, 2014 | 07:39 PM
pjv7771's Avatar
pjv7771
John
Tried that john and the Pistons pushed back in ok, I'm going to try the adjusting screw on the rod in the servo, it's my last hope !
Old Oct 31, 2014 | 10:22 PM
JPA's Avatar
JPA
Check what actual clearance should be using old master cyl before you start adjusting
Good luck
John
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
