rs turbo cutting out
Old Oct 7, 2014 | 06:53 PM
mbishop1964's Avatar
mbishop1964
Default rs turbo cutting out
hi my rs turbo keeps dying and cutting out when you give it some beans. if you leave it for a few seconds it will start again. it sounds like the fuel pump isnt working and then it will start working again. ive just rebiult it so dont know if it was like it before. any ideas
Old Oct 7, 2014 | 09:17 PM
Chas's Avatar
Chas
Any idea what the car is boosting at? How much fuel is in the car? The last one sounds silly, but my car suffers with fuel surge when the fuel level drops below 1/4 of a tank.
Old Oct 7, 2014 | 09:40 PM
liam-rst's Avatar
liam-rst
shit happens
That's because you have no swirl pot in your tank chas, what's the lil black plug on the top of your distributor like mbishop?
Old Oct 7, 2014 | 11:14 PM
Chas's Avatar
Chas
Without going off topic did they come with them as standard? I ask as some posts seem to suggest that even with a swirl pot the effects of running low will be present.
Old Oct 8, 2014 | 05:14 AM
liam-rst's Avatar
liam-rst
shit happens
Yeah they were standard in s2's for sure, not 100% about s1's though, one of my old ones was exactly the same and we discovers it was the wrong tank, was fine after it was replaced
Old Oct 8, 2014 | 06:33 PM
mbishop1964
thanks for the replys guys. theres a couple of gallon in the tank so could be low fuel. im going to change the fuel pump tomorrow and see if that does any thing ive got a spare. what do you mean about the plug on the dizzy. also could it be a knackerd fuel pump relay cutting out when warm. the boost is about 10 psi. cheers bish
Old Oct 8, 2014 | 10:20 PM
liam-rst's Avatar
liam-rst
shit happens
The black plug on the top of the dizzy, is it loose?
Old Oct 12, 2014 | 10:09 AM
mbishop1964
ive found the problem it seems fine if you keep it above 1/4 of tank. maybe sombody put a none injection tank in with out the swirl pot inside. unless sombody knows another reason.
bish
Old Oct 13, 2014 | 01:33 AM
Chas's Avatar
Chas
Is yours a Series 1 or 2? It would be interesting to see whether they should have a swirl pot or not .
Old Oct 13, 2014 | 11:53 AM
mbishop1964
its a series 2 1988. i bought it as a project so dont know much about apart from what ive done to it. it runs fine over 1/4 tank.
Old Oct 14, 2014 | 10:17 AM
HaggisTurbo's Avatar
HaggisTurbo
Originally Posted by mbishop1964
ive found the problem it seems fine if you keep it above 1/4 of tank. maybe somebody put a none injection tank in with out the swirl pot inside. unless somebody knows another reason.
bish
This sounds plausible, The thing is when you say a quarter tank is there really a quarter tank in there? remember these senders and gauges are over 20 years old and even new they were crap!
My old Escort and Orion both said you had a quarter tank when it reality you had a dribble e.g about £2 worth in the tank, One even ran out of fuel and the gauge was still above the red!
Worth thinking about
Old Oct 16, 2014 | 10:55 PM
Chas's Avatar
Chas
I recall that on both of the XR3is I have experienced the fuel pump would start grumbling around 1/4 of a tank depending upon what road you were parked on. One of them had a new fuel pump fitted (for a different reason) with no different a result.
Did they all have the wrong tanks or was there more to the story? You decide .
Old Oct 19, 2014 | 11:13 AM
Karlos G's Avatar
Karlos G
Balls Deep!
At the very least brim the tank to eliminate that as a problem before doing anything else as it could be many things.
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
Bailes1992
Aug 16, 2015 07:14 PM
turbobill
Aug 9, 2015 05:21 PM
