What power can I expect from my 2wd
Old Sep 28, 2014 | 07:48 PM
cossiedean84's Avatar
cossiedean84
Default What power can I expect from my 2wd
Hi everyone, as the title says......
I've just had my 2wd chipped and set up using ahmed chip, dark greens, 3 bar map sensor already had full s/s system and standard air box. It's running 21-20 psi so what power could I expect?
Old Sep 28, 2014 | 07:52 PM
Staffi's Avatar
Staffi
I'd say 320-330 at that boost
Old Sep 28, 2014 | 07:53 PM
Staffi's Avatar
Staffi
Is it on a T3 or T34??
Old Sep 28, 2014 | 08:08 PM
cossiedean84
It's on a standard t3
Old Sep 28, 2014 | 08:11 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
About 300 then.
What part of Kent are you from ?
Steve
Old Sep 28, 2014 | 08:13 PM
cossiedean84
I'm in Rochester. I had it set up at grove garage in essex and mark said it should be 300+ was just wondering what other people had out if there's. Don't know if it's worth getting a power run?
Old Sep 28, 2014 | 08:14 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im not far away, Herne Bay.
Always worth checking the fueling is ok
Steve
Old Sep 28, 2014 | 08:18 PM
Staffi's Avatar
Staffi
Originally Posted by cossie4i+
About 300 then.
Steve
Yeah like Steve says Dean, 300 ish.
My stage 2 T3 made 326 Bhp but that was peaking @ 2 bar stood up to the job though tbh, it was flat out, obviously they don't hold that boost.
Old Sep 28, 2014 | 08:21 PM
cossiedean84
Steve
I trust mark and ahmed have done the fueling as they fitted a lamba sensor in my down pipe and road tested.
Old Sep 28, 2014 | 08:31 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Should be fine then.
Don't get caught up in the power thing.
As long as YOU are happy with the way it goes that's all that matters.
Steve
Old Sep 28, 2014 | 08:33 PM
Jimboxr4x4's Avatar
Jimboxr4x4
My stage 1 Ahmed bayjoo chip made 292bhp on a standard t3 and 316 lbft.
Old Sep 30, 2014 | 10:33 AM
Cossy Mike's Avatar
Cossy Mike
Be interesting to see what mine will run similar spec
Live map NMS
Dark greens
3 bar map sensor
RS500 cooler
Hybrid stg1 TT T3 360° bearing 60mm compressor, -31
Old Sep 30, 2014 | 11:29 AM
fraser9764's Avatar
fraser9764
Live map NMS
Dark greens
3 bar map sensor
RS500 cooler
at what boost pressure?
Old Sep 30, 2014 | 06:01 PM
Cossy Mike's Avatar
Cossy Mike
Not sure? 20-22psi maybe?
Old Oct 1, 2014 | 07:39 AM
cossiedean84
Live map NMS
Dark greens
3 bar map sensor
RS500 cooler
I will let you know once I've had it power run, only thing I haven't got is the stage 1 turbo, I have the -31
Old Oct 1, 2014 | 05:36 PM
Cossy Mike's Avatar
Cossy Mike
Ok thanks
3doorcozmess
Sep 15, 2015 06:06 PM
dojj
28
Sep 11, 2015 10:00 PM
BRAM
Sep 8, 2015 07:11 AM
rsstav
Sep 7, 2015 04:43 AM
jc1989rs
Sep 5, 2015 08:09 PM
