Pectel Control Monitor
Old Sep 27, 2014 | 08:41 AM
LOUPAN's Avatar
LOUPAN
Default Pectel Control Monitor
Hello.
* My name is Sylvain.
* I'm a member of Club Cosworth France for 4 years and owned an Escort RS Cosworth Big Turbo Mallard Green 1992 .
I would like to know if anyone could help me about Pectel Control Monitor 16 way like this please :
I would like to know the pinout wiring diagram please .
I did a lot of research in vain
* I have also a Braided engine wiring loom which part with 7 wires without socket .
This 7 wires without socket goes to the 35 way Ecu socket for pin n°3 ( Crank) , n° 25 (Ignition module ) , n°15 ( Map ) , n° 1 ( Ground ) , n°17 ( Tps ) , n° 29 ( Engine coolant T° ) and n° 20 ( +12 V )
I thought these 7 Wires without plug was here to connect a Pecel Monitor For exemple . . .
Thank you for reading me .
Live and Breathe Ford !
Sylvain .
Old Sep 27, 2014 | 05:05 PM
oldford's Avatar
oldford
The Pectel Control Monitor communicates with the engine ecu over 2 wires.
That does mean you will need an eprom that supports this.
It may also mean you will need a hardware modification to the ecu (P8).
What ecu are you running and what kind of software? Standard? Mapped? Group A?
Old Sep 29, 2014 | 06:38 AM
LOUPAN's Avatar
LOUPAN
Hello .
Thanks OldFord to try to help me .
I know the Pinout wiring diagram for 9 Way Pectel Control Monitor
This version use 4 Wires : +12V( pin 20 ) , 0V Out ( pin 11 ) Diag in ( pin 8 )
Diag out ( pin 27 ).
But i' looking for the 16 way pinout diagram as on the previous pic .
I'm running a programmable Ecu made by http://www.societe.com/societe/posit...504976887.html
it's also the same company that has mapped my engine .
I would like to understand who are this 7 wires without socket plug on my engine wiring loom . . .
Thanks for help .
Live and Breathe Ford .
Sylvain .
Old Sep 30, 2014 | 06:34 AM
oldford's Avatar
oldford
Why are you showing my email server?
Please REMOVE!
Old Oct 1, 2014 | 05:45 AM
LOUPAN's Avatar
LOUPAN
Please REMOVE!
Sorry ,it's an Error !
I wanted to post a link with 11 pages about 9 Way socket plug Pectel
Control Monitor .
Old Oct 1, 2014 | 08:56 PM
grcossie's Avatar
grcossie
Try Oddkidd or Jimbo on here, think they will be able to help you
Old Oct 2, 2014 | 05:41 AM
LOUPAN's Avatar
LOUPAN
Hello Grcossie .
Thanks for your advice but how to contact this men please ?
With a private message ?
Thank you .
Sylvain .
Old Oct 2, 2014 | 09:39 AM
grcossie's Avatar
grcossie
Originally Posted by LOUPAN
Hello Grcossie .
Thank you .
Sylvain .
Yes you can send them a privat message
Old Oct 8, 2014 | 06:17 AM
LOUPAN's Avatar
LOUPAN
Hello .
Before trying to contact Jimbo or Oddkidd , i have try to find the answer myself .
Mr the original write in a post : ecu pin 8 to pectel 16 way pin 3
11 to 12 (vref -)
20 to 2 (positive supply)
27 to 5
Thank you for this information .
What i would like understand is why i have 7 wire without plug goes to the 35 way Ecu socket for pin n°3 ( Crank) , n° 25 (Ignition module ) , n°15 ( Map ) , n° 1 ( Ground ) , n°17 ( Tps ) , n° 29 ( Engine coolant T° ) and n° 20 ( +12 V )
I gladly accept a little help on this topic
Thank you .
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
jay030787
Sep 25, 2015 01:38 AM
Roscopeco
Sep 14, 2015 05:32 PM
