st170 rs turbo
Old Sep 26, 2014 | 05:13 PM
pauloopnorth's Avatar
pauloopnorth
Default st170 rs turbo
Hi I could do with a bit of advice ive been offered a slightly damaged focus ST170 and was wondering if the engine would match up to my RS turbo cvh gearbox ,as im in need of a new engine in the escort , has anybody ever put a st170 engine into a rs turbo and used the standard box ? or know of any pitfalls and what to look out for that might be tricky ,any help and advice would be much appreciated
Old Sep 26, 2014 | 05:20 PM
gjh's Avatar
gjh
https://passionford.com/forum/ford-e...onversion.html
Lots of good info in that thread.
Old Sep 27, 2014 | 09:06 AM
crazycage's Avatar
crazycage
The engine will bolt straight up ,you will need to drill out the holes on a cvh flywheel to 11mm and that will fit allowing you to use a rst clutch.only other mod you will need is to the rear of the sump you need to cut the corner off to give room for the inner cv on the escort shaft.when you offer it all up it will make sence
Old Sep 27, 2014 | 09:47 AM
HaggisTurbo's Avatar
HaggisTurbo
The only main thing I can think of mate is how to deal with the variable timing in the head as they used a specific ecu to control it
Old Sep 27, 2014 | 11:57 AM
crazycage's Avatar
crazycage
We run the vvt on Ms3
Old Sep 27, 2014 | 01:18 PM
studabear's Avatar
studabear
Does it make much of a differance?
Old Sep 29, 2014 | 03:52 PM
pauloopnorth
Thanks for the wisdom chaps , with regards to the ecu I have the complete focus still as a running car so was hoping to use the complete engine loom and wiring including st170 ecu , in the escort? Was not planning on adding a turbo just yet just keeping it basically stock st170 spec
Old Sep 29, 2014 | 04:09 PM
studabear's Avatar
studabear
That will require a lot of work to use the focus ecu.
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
kevin36
Sep 2, 2015 06:24 PM
