No fuel at the injectors when cranking
Hi all, help needed again
The series one won't start again
There's no fuel getting to the injectors however the car fires for a second and the plugs are wet so I assume the cold start injector is getting some fuel in. There's fuel getting to the metering unit as I have checked but none coming out of the 4 fuel lines
Now the car will go if bumped and runs not to bad but will not start off the key
Battery is new as are the tank, lines, filters,plugs dizzy etc etc
Any ideas pls
Any ideas pls
DixieTheKid
11
Jun 6, 2020 11:20 AM
