Washer pump earth
Old Sep 23, 2014 | 08:39 AM
johnboy73's Avatar
johnboy73
Default Washer pump earth
hello,can anyone tell me where the washer pump earth point is?ive replaced the pump and still can't get the pump to work and it's mot day tommorow.
Old Sep 23, 2014 | 07:05 PM
DazC's Avatar
DazC
Pump is live fed from the ignition. The earth runs back into the car and through the column switch then to earth, presumably on the A pillar behind the speaker cover as there is a common earth point there. It's a switched earth and not a switched live.
Old Sep 24, 2014 | 12:10 PM
martysmartie's Avatar
martysmartie
In your other thread you mention you don't have a supply, thus the ground is not the issue!
Martin
Old Sep 24, 2014 | 06:54 PM
johnboy73's Avatar
johnboy73
Got the washer pump sorted,thanks for your help Martin.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
20/20 vision
Sep 29, 2015 11:27 AM
DavidK
Sep 27, 2015 02:55 PM
