Thermostat problem - please help!
Old Sep 22, 2014 | 08:27 PM
moondustka's Avatar
moondustka
Boooost!
Default Thermostat problem - please help!
Hi everyone,
Hoping some of you can chuck some ideas to me. My car appears to be eating thermostats like its fuel!
Bought a new one from Ford, then another, and now a 3rd one (this time from Euros) and each one has done exactly the same thing. Solved the prob once put in and bled the air - car would run from 88-90 degrees. Perfect. Until about 50 miles happens and then for whatever reason car drops in temps and struggles to keep 70-75 degrees.
I did check one of the Ford ones in the saucepan with a decent digital thermometer and found it opens at roughly the right temperature but then stays slightly open down to 70 degrees.
Car is a Puma. Engine is MK1 FRS. It runs an aluminium escos radiator. Omex management - I'm monitoring temps with laptop as I drive at the moment.
I don't understand why they work for a bit and then die?!
Any help appreciated.
Ben
Old Sep 26, 2014 | 08:08 AM
moondustka's Avatar
moondustka
Boooost!
After a bit more investigation it's clear that the thermostat is all over the place. Also I think the heater matrix isn't getting enough flow when the thermostat is open? As it if left on hot, it blows nice hot air for a bit and then goes cold. Then it will come back again.
This all seems centred around the thermostat. But I don't understand why they work for a bit and then break?!
The thermostat housing isn't a focus rs one, I think I took it off a 2.0 mondeo or something. But I can't see how this would make a difference as the thermostats are all the same?
DAZZER
Sep 30, 2015 08:43 PM
The Enigma
Sep 29, 2015 10:31 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
