Pf09 tps
Old Sep 21, 2014 | 08:28 PM
mark r's Avatar
mark r
Default Pf09 tps
Hello could someone explain to me the correct way of setting up pf09 tps sensor as mines not set up correctly
Thanks mark
Old Sep 21, 2014 | 08:31 PM
Cossy Mike's Avatar
Cossy Mike
Volt meter set to 20v
Then black probe on pin 17 and red on pin 11, voltage should be 0.23v with ignition on engine not running.
Slacken off the 2 screws holding the tps to the throttle body and turn it in whatever direction you need to get to 0.23v then nip up the screws.
Old Sep 21, 2014 | 10:13 PM
mark r's Avatar
mark r
Thank you very much
Mark
DixieTheKid
11
Jun 6, 2020 11:20 AM
muffster
13
Sep 3, 2015 09:40 PM
cozzy jeff
Aug 31, 2015 04:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Roosie
Aug 15, 2015 08:09 PM
